My Berks finally arrived, but is this normal?
Old Apr 9, 2009 | 03:21 PM
  #31
2GoRNot2G's Avatar
^ Yup, my thoughts exactly.
Old Apr 9, 2009 | 11:08 PM
  #32
tylerxfire's Avatar
quick question, if u shake the whole cat back and forth does the inside wire part shake around at all(from one end to the other if u move it back and forth), or is it totally fixed and not moving? thanks
Old Apr 10, 2009 | 02:04 AM
  #33
Csquared's Avatar
^what inside wire? Last time i was shaking it it shook all the way back to the motor and the other side starting shaking too.
Old Apr 10, 2009 | 04:41 AM
  #34
Defratos's Avatar
You're Despicable
Originally Posted by Scooby24
oh geeze you guys, those look fine. my goodness. I've gotten some before that were bent nearly in half and they still seal perfectly. They have a flexible gooey material in them that when clamped, will compress and seal no problem. The thread hanging off looks like just a piece stuck on from the manufacturing process of cutting out the piece. I bet you could just yank it off and not think twice about it.
Yeah I probably could yank it off, thanks for the help, I wouldn't have liked recieveing it half bent lol
If you mean with the HFCs not installed then no there's no noise
Old Apr 10, 2009 | 10:46 AM
  #35
tylerxfire's Avatar
yeah of course i mean when its not installed...when the cat is out of the car if u shake it around, does the metal wire part inside the actual cat shift around or does it stay completely still..
Old Apr 10, 2009 | 10:54 AM
  #36
Scooby24's Avatar
It should sit snug inside the canister. If it doesn't I would suspect the vibrations will cause it to break up. Every cat I've ever removed was snug as a bug in a rug.
Old Apr 10, 2009 | 01:23 PM
  #37
Defratos's Avatar
You're Despicable
Nope mine don't make any noises
Old Apr 10, 2009 | 01:24 PM
  #38
Csquared's Avatar
Mine stayed completely still.
Old Apr 10, 2009 | 05:43 PM
  #39
tylerxfire's Avatar
berk problem found
well heres my passenger side high flow cat...berk is going to warranty but
Attached Thumbnails My Berks finally arrived, but is this normal?-clogged-pass.-side-cat.jpg
Old Apr 10, 2009 | 06:15 PM
  #40
Scooby24's Avatar
uhhhh wtf?!
Old Apr 10, 2009 | 08:11 PM
  #41
tylerxfire's Avatar
uhhhh wtf?!
tell me about it...been on for a month, i am tuned my a/f is 11.8 rock solid with my vortech kit and i have had zero misfires..idk..
driver side is rattling around too so im sending that one back as well...just posting this up for people to look at with symptoms like car sounding different not having the same growl...hard to explain...got quite a bit quieter still had some power though is what got me, but idk i didn't go make hard pulls or anything so hard to tell if it lost power, ran fine though, just sounded different..berk is great to deal with though let me say and they are fixing the problem..
Old Apr 11, 2009 | 03:38 AM
  #42
Csquared's Avatar
what do you mean sounded different and why is it all blue?
Old Apr 11, 2009 | 08:31 AM
  #43
Scooby24's Avatar
Looks to me like they melted. EGT's got too high for them to take and they broke down. I've not seen it turn blue but I've not seen a failure on a 'high flow' cat either..
melted cat
Old Apr 11, 2009 | 10:08 AM
  #44
tylerxfire's Avatar
its not blue...its just from my flash on my phone....and it def. didn't get too hot...i havent tracked the car or taken it over an hour drive in a long time, or even beat on it...i went to the store came home on the highway made a 2nd, 3rd, and 4th gear pull and came into town to realize it just didn't sound the same and then put it away and pulled them yesterday morning..
Old Apr 11, 2009 | 10:09 AM
  #45
tylerxfire's Avatar
as far as sounding different it, was just quite a bit quieter all of a sudden, and didn't have the same deep growl and little pops on deceleration
