Nissan Power Pup Bullydog - First Impressions
#31
#32
yes you can use this for the 6mt.
ok done.
Suby you da man. LOL
Thanks for the vid. 7500-7800 is normal with DS it shifts around 500 lower than limit. So before it was shifting around 7k rpm and was finish shifting just before would hit redline. Now since redline raised everything else with it. Even the next gear rpm too.
Cool.
You rock bro.
Cool.
You rock bro.
IDK guys im just providing my personal outcome. people had ?'s if it worked yess it does. you dont have to use the tune it also reads engine codes can take off speed limiter a lot of previous threads about how the AT's wanted to go past 130. wtih this you can all the above. just trying to help.
#34
any word on the wide open throttle issue found in the Nissan trucks?
most reviews said that taking the WOT restriction off was the biggest single improvement.
FYI,
the WOT restriction was on the titans, it restricted WOT under 40 mph,
so basically when u stomped on it, it would only get you about 88% throttle until you pass 40 mph, then you would get 100%
FYI,
#36
FYI,
FYI,
#37
the trucks restriction is on the other end when starting off,
i also read that some people who had the 4runner had the WOT and the first few maps that came out did not remove this restriction. They called bullydog and requested a new map with the wot removed.
bullydog responded in a few weeks with a new map for that restriction.
so maybe suby should call and ask about it and see what they say.
#38
#39
but i havent noticed the option in there either.
#43
#44
#45
On Maxima's, advancing the timing by 2 degrees netted a few hp and better throttle response - so long as you're on high octane gas. However, it was later argued that the ECU compensated for the advanced timing and dialed it back in. I didn't follow the topic long enough to see if that was verified.
