What's the "pecking" order as far as A/M BBK brakes?
Old Jun 2, 2009 | 06:49 PM
rookie's Avatar
Originally Posted by san~man
$4250 F and $3295 R Yikes.
Can be had for less, that's list price. Who pays list? hahahaa
Old Jun 2, 2009 | 06:51 PM
E-Ticket Ride's Avatar
Originally Posted by Jeff92se
Weight savings? Not sure where you are going with this. Weight of the caliper/bracket is almost irrevelant accross brands. The weight is in the rotor. If you are concered with weight, that means 2 pc rotors. But bigger dia 2pc will weigh more than smaller ones.
As said, depends on what you are doing. You really need 14" or 15" rotors?
Some brands (Wilwood for example) offer "lighter" calipers than other brands. Not saying that it makes it better/worse, but they do. I'll probably end up with 2 pc rotors in the end.
Won't a larger rotor allow more pad contact area, which should theoretically offer better stopping distances? I know this doesn't exactly apply to all cases, since the 37 with larger rotors stops the same/little less than the 08 sedan sport brakes. I don't necessarily need a 15" rotor, but I would think that a 14" rotor is "reasonable."
Old Jun 2, 2009 | 06:53 PM
I know, but still.....I would say I probably don't need anything of that caliber
Old Jun 2, 2009 | 06:57 PM
Jeff92se's Avatar
Red Card Crew
Like I said, weight differences inbetwen brands ins't going to make or break you. When you say "I'll probably end up with 2 pc rotors", that means you aren't serious about weight savings or you're priorities aren't in the right place. Difference inbetween let's say an oem Akebono 14" 1 pc and an aftermarket replacement 2pc is probably close to 8-10lbs each. The difference inbetween 2 different calipers is going to be less than 1 lb. AND the rotor is rotating mass vs non rotating mass of the caliper. Rotating mass is much more critical weight wise.
I'd go oem Akebono w/ aftermarket 2pc front and back. Perhaps not the bling but definately functional, light and probably the cheaper option. Just powder coat them if you want them blingity
Old Jun 2, 2009 | 07:02 PM
rookie's Avatar
The oem akebono pricing is a such a sick deal vs aftermarket. Once aftermarket rotors catch up it will be an even better deal.
Old Jun 2, 2009 | 07:09 PM
jran76's Avatar
Stoptech. I used their kit on my 04, and it was top notch in all areas (quality, performance, available pads, and customer service/support). I would consider other top brands like Brembo, Endless, and Project Mu, but for the price you can't beat the Stoptech's. I would personally stay away from untested brands (Rotora and pieced together Wilwood kits, etc.). It's just not worth it when you can get a Stoptech kit for the same price....
Old Jun 2, 2009 | 07:13 PM
Jeff92se's Avatar
Red Card Crew
ConceptZ is working on getting 2 pc rotors available.
Old Jun 2, 2009 | 07:20 PM
bigc's Avatar
Wings Nation
I haven't done much research. What do the OEM Akebono rotors weigh?
This Brembo 380mm front rotor weighs 19.4lbs
those would look sick on your FX
Old Jun 2, 2009 | 07:25 PM
rookie's Avatar
It's cool the 370z can share the parts so the manufacturer would be smart to make the parts needed!
For comparison, a Rotora 380mm rotor and hat weigh 24lbs, that's pretty significant vs the Brembo of the same size. Aluminum vs steel hats will make a big difference, hopefully the Akebono rotors are made with aluminum and it's good aluminum at that.
Brembo Monobloc 6 caliper full assembled weighs in at 11lbs. I can't remember what my Rotora 8s weigh but they are hella heavier than that.
Old Jun 2, 2009 | 07:26 PM
bigc's Avatar
Wings Nation
my 6 pot Rotora front calipers weigh 12.98 lbs each
Old Jun 2, 2009 | 07:29 PM
rookie's Avatar
Nice! I guess this thread is starting to have some decent info in it. What do the Akebono calipers weigh, and what do the oem rotors weigh for the second gen sport brakes?
Old Jun 2, 2009 | 07:31 PM
Jeff92se's Avatar
Red Card Crew
Front Akebono 1 pc rotor is something like 26-28lbs. But someone posted 30lbs.
For instance, a 11.5" 03 1pc rotor is 15 lbs. The 12.6" oem rotor is 18lbs. Adding 10-13lbs of rotating mass is killer. Although it's not an equal comparison, would you guys like to have wheels that are 10-13 lbs heavier?
IMHO, if the newer sport Gs with 1pc Akebonos swapped out to the 2 pc fronts, I'm sure it would make a difference one could notice.
Old Jun 2, 2009 | 07:33 PM
rookie's Avatar
What about the Akebono calipers? Share the knowledge man! lol
Old Jun 2, 2009 | 08:01 PM
Jeff92se's Avatar
Red Card Crew
haha. I never really concerned myself with caliper weight. They are all forged aluminum and are all lighter than the oem cast iron calipers. Plus, they aren't rotating mass.
Old Jun 2, 2009 | 08:07 PM
  #30
rookie's Avatar
I'll be picking up a set of rear Brembo 4s tomorrow. I'll get the weight of those. http://my350z.com/forum/brakes-and-s...03-07-g-z.html
Adapter Brackets, front left and right: 1.8lbs
Hardware, front: 2 lbs (reuse existing rear hardware)
Front Calipers: 10 lbs each
Rear Calipers: 5 lbs each
Front Rotors (14" Stoptech Slotted): 27lbs each ()
Rear Rotors (13.8" OEM blanks, vented): 18lbs each ()
