Installed: Invidia Q300 Exhaust
Old Jul 8, 2009 | 07:05 AM
  #286
G35s-Q8's Avatar
Finally my Invidia exhaust arrived at my company in the US, i should have it delievered to my door steps on Sunday, i'll post pictures before/after i wrap it with thermal heat wrap and then i'll post more pictures when it's installed .
Old Jul 8, 2009 | 07:13 AM
  #287
Defratos's Avatar
You're Despicable
So the only benefit from the Thermal heat wrap would be less rasp?
Old Jul 8, 2009 | 08:47 AM
  #288
G35s-Q8's Avatar
Yes, and some other stuff that i can't explain, for example take the exhaust pipes when it arrives and try hitting it with a spoon, you'll hear echo inside the pipe, wrap it with a piece of cloth and hit it again, you'll never hear anything, that's the whole idea, but since it's a hot thing, you need thermal heat wrap, don't wrap it with a cloth, it's just an example, or your car would catch fire and burn and explode .
Old Jul 8, 2009 | 09:06 AM
  #289
Borna's Avatar
Hmmm...that's not a bad idea...
Would thermal heat wrap reduce drone?
Old Jul 8, 2009 | 01:30 PM
  #290
G35s-Q8's Avatar
Hmmm...I'm not sure about drone, but maybe not, or maybe a little, but it's erease raspy exhaust sound, give me 5 days to recieve my exhaust and then test things out, but as Robby said, there is no drone/rasp at all, only tiny rasp when it's cold and it goes away in 2 minutes.
Old Jul 8, 2009 | 02:18 PM
  #291
beezy619's Avatar
Can you give us a link to which thermal wrap you are using? Is it the one you can buy at Home Depot or Lowes?
Old Jul 8, 2009 | 02:43 PM
  #292
E-Ticket Ride's Avatar
It's probably safer to use one from Summit or Jegs, or the like. At least you know it's for automotive use, so it may/may not withstand the elements better than one designed for the home.
Old Jul 8, 2009 | 05:01 PM
  #293
G35s-Q8's Avatar
Just like you said, i got it from summit, here's a link:
http://www.summitracing.com/parts/TH...3/?image=large
I got the 100ft long since the Invidia pipes are long, so when i wrap it i'll see if the 100ft long Thermo-Tec wrap is enough or not, i got brand new 50ft long one here at home somewhere, i just have to dig it out, but i'm planning to use the 100ft long 1st.
Old Jul 8, 2009 | 05:04 PM
  #294
Borna's Avatar
Oh ok.
My FI exhaust has no rasp at all. Not even at a cold start. So I don't have that problem.
But the fact that I got the round mufflers gives me a bit of drone at lower speeds so I wouldn't mind getting rid of it somehow. Of course, without adding or changing anything on the exhaust.
Old Jul 9, 2009 | 01:55 PM
  #295
G35steve's Avatar
So has anybody dyno'd with the Invidia system i need to know.
Old Jul 9, 2009 | 03:10 PM
  #296
G35s-Q8's Avatar
Won't really matter, since all mods work together, so if you need to compare some exhaust, it should be done on a stock car.
Unless someone with a stock G35 get a some cat-backs and compare all of them, like making a report, but i think it's hard to be done, so i guess just get the exhaust based on the reviews.
Old Jul 9, 2009 | 05:09 PM
  #297
G35Robby's Avatar
I cant dyno it cuz my car is modded to the ying yang lol
But even with a reflash i felt power gain. Especially low end
Old Jul 9, 2009 | 10:33 PM
  #298
Austin713's Avatar
Honestly I think exhaust is 100% about sound. I have heard a few clips of the invidia and they all sound raspy. Every FI I have heard has been deep and mellow.
Gains don't matter. I don't care if my
exhaust makes
20 rwhp if it sounds like *** I don't think o could ever put it on my car.
Old Jul 9, 2009 | 10:43 PM
  #299
beezy619's Avatar
To each is own. Robbie's updated video clips shows no rasp. Mine still has rasp when the exhaust is cold, but like Robbie's my rasp is slowly going away. When warmed up, it sounds just as sexy as the FI exhaust. I wanted an FI exhaust for the longest, but couldn't justify spending $1200 on an exhaust. The Invidia was a good compromise.
Old Jul 10, 2009 | 02:44 AM
  #300
G35Robby's Avatar
My exhaust is not raspy anymore. Only in the morning for like 10 seconds lol
I love it sounds now and it actually got mellower and sounds fvcking aggressive now. I want it to be louder lmao
