high rpm = warning light
Old Sep 1, 2009 | 04:47 PM
simsimi1004's Avatar
when i suddenly acclerate past like 3.5/4 k rpm, the red warning light comes on (The light that comes on when e.brake is engaged), when i stop accelarating it turns off. no, im not slipping, and i also dont hear unusual noise.
im leaving the country in a week, and wont probably get an appointment till i come back which is in 2 month! T.T
Old Sep 1, 2009 | 05:07 PM
CalsonicVQ's Avatar
You are probably low on brake fluid. Add just a tiny bit, just enough to get rid of the problem.
Old Sep 1, 2009 | 05:26 PM
can low brake fluid also cause squeling?
Old Sep 1, 2009 | 05:34 PM
AesonVirus's Avatar
The slip light can flash even if there isn't OBVIOUS slipping.
It's normal.
The brake fluid top-off only corrects the brake light coming on and staying on. It has nothing to do with the slip light flashing while under heavy acceleration. (if that is in fact what is happening)
Old Sep 1, 2009 | 05:54 PM
Austin713's Avatar
LOL 3.5k isnt what i would call high for our engines... most of us see that every day.... i would agree with the brake fluid thing though.. check it out
^^its not the slip light that comes on, its the e.brake light.
^ yea 3.5k isnt high, but when i push more than 60-70% of the pedal, when its going past the 3.5k (its when the light comes on) heading towards 4-8rpm. the light stays on unless i let off the pedal.
Old Sep 1, 2009 | 09:36 PM
Defratos's Avatar
You're Despicable
if it stays constantly on until you let go of the pedal with no obvious slipping then that's not normal
Old Sep 2, 2009 | 07:51 AM
snowcrossmxz's Avatar
might be the switch on the ebrake is out of adjustment and the G force from acceling causes it to trip.
Intake & Exhaust
Jul 19, 2015 04:30 PM
mjfenix
Jul 17, 2015 02:07 PM
Jadenkid22
Jul 14, 2015 12:33 AM
