water leaking
Old Oct 16, 2009 | 11:34 AM
G35@2007's Avatar
water leaking
Dear All Member
i replaced the radiator for my car ( G35 2007 sedan ) because it had damage from an accident , but now , when i turn off the car after driving , all the water which in the radiator , coming out from the hose which in the spare tank .
also i replace the thermostat , because i thought its block but still the water coming out
any solution please
Regards
Old Oct 16, 2009 | 02:18 PM
tg1234's Avatar
Ah It is a closed system. Water should not come out at all. Are you sure you connected all the hose to the right place include the overflow? Maybe it is time to look at another G and see if everything in place otr check the service manual if you have that.
Old Oct 16, 2009 | 02:50 PM
pfarmer's Avatar
Originally Posted by G35@2007
Dear All Member
any solution please
Regards
All the water or only some of the water? You may just need to purge the system of air.
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
KallDay86
Jan 8, 2016 12:42 AM
hrdwirk1
Oct 2, 2015 06:34 PM
NyCrAzY
Oct 1, 2015 09:19 AM
vamarris
Sep 26, 2015 12:56 PM
