weird noise at WOT
Old Jan 3, 2010 | 09:27 PM
bat6wc's Avatar
weird noise at WOT
So the other day my friend wanted to see what my car could do, so I punched it and at WOT i heard a very odd noise. Like rattling, raspiness/scratching coming from what seemed to be engine/throttle bodies. Thats the first time ive heard that noise. Only the 2nd time ive WOT'd it. Well tonight, again at WOT, i heard the noise. Any ideas? Intakes? Cold weather?
Last edited by G35Now!; Jan 3, 2010 at 11:31 PM. Reason: No street racing commentary
Old Jan 3, 2010 | 11:03 PM
E-Ticket Ride's Avatar
Pinging, maybe due to crappy winter gas
Old Jan 3, 2010 | 11:07 PM
bat6wc's Avatar
could it be due to the intakes? causing me to run lean? it has been in the single digits, temperature-wise, here for a couple days now.
Old Jan 3, 2010 | 11:30 PM
G35Now!'s Avatar
Moderation-free
When it shifted, or while approaching redline? During shift is a known problem, haven't heard of anyone having the problem between shifts.
Old Jan 3, 2010 | 11:35 PM
bat6wc's Avatar
approaching redline, at higher rpms. it doesnt seem shift related.
Old Jan 4, 2010 | 01:14 AM
A new problem, or has it been ongoing?
Old Jan 4, 2010 | 01:18 AM
codeflux's Avatar
sure sounds like you're describing pinging.
Old Jan 4, 2010 | 01:19 AM
bat6wc's Avatar
so is it 1. intake problem, 2. cold weather issue 3. combo of both
like i said, ive only WOT'd it a total of 3 times. I dont remember hearing any noise the first time and that was with stock intakes at normal temps.
Old Jan 4, 2010 | 02:13 AM
Could be a batch of bad winter gas too, as they change the formula during winter vs summer.
What octane gas are you using now? (91, 92, 93?)
Do you have access to 100 octane around there?
If you can get 100, pump in enough to raise the octane to 94'ish and see what happens.
Old Jan 4, 2010 | 10:32 AM
bat6wc's Avatar
i always use 93octane fuel...no 100octane around here
Old Jan 4, 2010 | 11:30 AM
Glover997's Avatar
exact issue i had b4 . . i got rid of my intakes , put stock back in . . then WOoooolaa . . problem gone !!
i was running R2c BTW !! Lean as well !!!
Old Jan 4, 2010 | 01:39 PM
bat6wc's Avatar
so you were pinging and running lean in warm temperatures too?
any A/F numbers?
Old Jan 5, 2010 | 11:34 PM
PursuitofG's Avatar
I experience the same weird noise at WOT with my r2c intakes. also others on g37 board
Old Jan 6, 2010 | 02:57 AM
Q8y_drifter's Avatar
so the only 3 guys to have that issue use R2C intakes. Stick the stock intake back in and see what happens...
Old Jan 6, 2010 | 03:07 AM
2GoRNot2G's Avatar
Sounds like pinging to me as well. This can be caused by excess moisture in the gas tank when the weather get cold. Note that the moisture usually comes from water condesing inside the underground storage tanks at the gas station and then transfered to your cars tank via the gas pump.
Marlin84
Apr 1, 2020 12:52 PM
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
RichardP9
Drivetrain
Oct 26, 2015 11:25 PM
dcsbh1
Oct 1, 2015 03:15 PM
alinero718
Sep 27, 2015 09:35 PM
