Idle timing issue/engine replacement
Old Sep 30, 2010 | 12:34 PM
KaWhite's Avatar
Looking through the internet I've seen the problem I'm having with my car is very common to other G35 Infinit owners (purchased 08). The car starting turning off while it was in the idle position or the power would shut off in the middle of the road and the wheel would lock. I've taken it in FIVE times without it being fixed. Now, the car is blowing smoking, and burning through oil like crazy. I've taken it to 2 dealerships and they are saying it is not under warranty. The car has had regular oil changes, pads, filters, tires, everything is needs. I had to file a complaint with the BBB because I don't know what else to do. Anyone had to deal with this?? Thanks so much.
Old Sep 30, 2010 | 12:59 PM
tg1234's Avatar
This is actually the first I heard. If it is 08 model and your milage is in the range you should have powertrain warranty. What is your milage? Is it an 08 sedan?
It is the first I heard this.
Old Sep 30, 2010 | 01:34 PM
KaWhite's Avatar
2008 g35 sport 4 door. 45k miles.
Old Sep 30, 2010 | 01:38 PM
CerveloR3-SL's Avatar
How many miles do you have on your car?
What year is your car?
Did you do all your service with Infiniti?
I have an 08 and I have not had any problems at all.
Smoke usually means you have oil/coolant leaking into the engine.
edit. oops i was slow on the posting
Old Sep 30, 2010 | 01:40 PM
At your miles i would contact infiniti NA and/or ask another dealer.
Old Sep 30, 2010 | 05:14 PM
KaWhite's Avatar
I've asked another deal but it's in the system that they have denied the warranty so no luck. What do you mean "NA"
I've been told the smoking is caused by the car burning oil so fast.
Old Oct 1, 2010 | 01:20 AM
tg1234's Avatar
How can they deny warranty work? It is under warranty.
That's crap. Check your warranty booklet. It should tell you. If it doesn't have a salvage title you should have warranty.
Old Oct 1, 2010 | 05:34 AM
NationsMostWanted's Avatar
very interesting topic...
Old Oct 1, 2010 | 09:05 AM
armoredmoonman's Avatar
Infiniti Consumer Affairs
P.O. Box 685003
Franklin TN 37068-5003
800.662.6200
8:00 a.m. - 5:00 p.m. Eastern / Central Time / Pacific Time
Monday through Friday
8:00 a.m. - 3:00 p.m. Central Time
Saturday
Old Oct 1, 2010 | 11:07 AM
blnewt's Avatar
Like mentioned, unless you have a salvage title or a documented lack of maintanance, your case should be a warranty issue, especially since you've had to take it back for the same issues 5x.
I haven't heard of that problem you've experienced, or if I did it was so rare that I've forgotten about it. Definately take it up the ladder. Burning up oil is definately very serious and I wouldn't even drive it anymore.
Old Oct 1, 2010 | 03:33 PM
P.O. Box 685003
800.662.6200
Saturday
This is what I mean... NA Infiniti North American Consumer Affairs..
Old Oct 2, 2010 | 01:59 PM
IvoryPearl07G's Avatar
you have aftermarket modifications to it?
rule #1 is to take it in ONLY when stock
Old Oct 4, 2010 | 10:29 AM
MiniRX7's Avatar
Agreed,
Any aftermarket parts, and they try to blame that. My engine blew and the warranty was questionable... ALl i had was stillen exhaust and stillen intake.
However, they replaced it under warranty on mine. But i still had major problems.
Hence, i am picking up my 2010 G37S Coupe tommorrow!
Old Oct 14, 2010 | 02:46 PM
Glover997's Avatar
i believe the guy is in GCC, so NA is not what he's lookin 4 !
you may shoot the M.E's instead .
all the best . .
KevinnnVo
Oct 14, 2024 04:33 PM
Muski_G
Dec 1, 2023 11:11 AM
ghost_g35
Aug 7, 2015 10:31 AM
Rehman2009
Jul 27, 2015 03:23 AM
itschuckster
Jul 25, 2015 08:07 AM
