Ram Air Intake system question
Old Jul 5, 2011 | 10:33 AM
TheAdrenaline's Avatar
I'm looking into getting a ram air system and ive narrowed it down to 2, wanted to see if anyone has any Pros/Cons on either or both.
aFe 54-11092 Stage 2 Air Intake System
-or-
K&N 69-7081-1TS Typhoon Silver Air Intake System
Old Jul 5, 2011 | 10:45 AM
DFWG35driver's Avatar
Neither of these are classified as RAM intakes. These are conical open air filter intakes and I wouldn't waste my money on either. Inside the engine bay open air intakes have been proven to lose power instead of gaining power. If you want a cool sound then do it. If not just change your drop in filters to K&N, it will give you more power. If you're serious about an intake I would look into the CAI. Stillen or Injen make the best ones as far as I can see.
Hope this helps, I would hate for you to waste your money.
Old Jul 5, 2011 | 10:53 AM
The only issue to the CAI is where i live it does rain often and we do have snow about 3-4 months a year and i had a CAI in my 3rd gen eclipse before and i fried 2 motors because of water being sucked into the CAI. I think i have a Z-Tube already installed (i just got the car used earlier last week) but im looking for something to help with gas mileage while also giving me a little more power when needed.
Old Jul 5, 2011 | 11:01 AM
http://www.stillen.com/product.asp?i...W03&c=PE&m=all
I would look into this setup. It's pricey but unless you drive into a lake you won't have any water induction problems. I'm running the Injen Sp1997p and I constantly worry about hydro lock, but I'm in Texas so it's not so bad. The stock intakes on the G35's are setup to pretty much maximize airflow. If you want more power I suggest the drop in K&N filters. They are around 50 bucks each but greatly improve air flow and are cleanable.
Old Jul 5, 2011 | 11:19 AM
vqsmile's Avatar
-or-
I hope you realize that you are in the V36 section asking about intakes, while your sig indicates you have a V35
BTW, V36's have so called "ram air" built in from the factory.
Old Jul 5, 2011 | 11:22 AM
^^^ I didn't even look at his sig. I fail. Yeah the V36 is essentially RAM from the factory!
Old Jul 5, 2011 | 11:25 AM
I know but no one from the V35 section gave me an answer and i know the engines are the same at the core
Old Jul 5, 2011 | 11:33 AM
vqsmile's Avatar
You'll probably still get more info there than here though. Maybe they're just trying to force you to search more. If it's an answer that's been discussed many times, that will often be the type of response you will get. Anyway, have you looked into a plenum spacer? You will stand to gain more there than with just an intake.
Old Jul 5, 2011 | 11:36 AM
PandaBear62's Avatar
HKS drop in is the best!
Old Jul 5, 2011 | 11:37 AM
Vq do you know when they are going to release a plenum spacer for the 36HR?
Old Jul 5, 2011 | 11:59 AM
vqsmile's Avatar
Absolutely not. I was just mentioning it for his V35. I would be surprised if they even do come out with one for our HR since the stock one is vastly improved from the previous generation's and has probably netted nearly all, if not all, the gains available there. I could be proven wrong, but that's my take on it anyway.
Old Jul 5, 2011 | 12:18 PM
Oh ok thanks bro.
Old Jul 5, 2011 | 01:22 PM
nghiars's Avatar
v35s have a short ram intake from the facorty as well. Z tube with a K&N drop in will increase air flow but no intake will help you improve mpgs in this car.
Old Jul 5, 2011 | 04:34 PM
kool_yaar's Avatar
^ whs, in the previous gens hey had the issue where cause of lack of space between the plenum and strut/hood and therefore shorter cylinders on some causing the need for a spacer, on 07+ as vq said this has been cured fully and the intake manifold/plenum is made out of 1PC plastic so from what i see, a spacer is not possible IMO.
Gip
Aug 24, 2015 05:31 PM
RA102223
Aug 15, 2015 09:24 PM
underworld
Aug 6, 2015 01:36 PM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
paniaguag35
Jul 29, 2015 12:05 PM
