Remove pedal cluster?
Old Mar 17, 2012 | 12:16 PM
Scott Andrew's Avatar
Hi, so I just got a SprintBooster and I am trying to install it but I have no idea how to get the cover off behind the pedal to get to the pedal module? Any ideas?
I have a 2008 G35x
Thanks
Old Mar 17, 2012 | 02:26 PM
vqsmile's Avatar
If you're talking about the whole gas pedal assy, then you have to pop the cover off the very bottom (where it hits the floor, closest to the seat, under the floor mat). There should be a couple bolts hidden under there that hold it down.
btw, I've never actually done this, this is just according to the service manual (which you can download for free from infinitihelp.com), it's listed under "Accelerator Control System" )
Old Mar 17, 2012 | 03:46 PM
perfect, thank you very much for both the link that I didn't know about as well as how to remove the assembly, it was exactly as you explained
Old Mar 17, 2012 | 05:46 PM
vqsmile's Avatar
No problem Scott. IDK why they don't sticky that link for access to a free service manual; seems like a lot of folks could benefit by it.
Old Mar 17, 2012 | 06:54 PM
Triton3.5's Avatar
whats a sprintbooster anyway??
Old Mar 17, 2012 | 07:45 PM
vqsmile's Avatar
It cheats the DBW throttle setup.
(Theoretically, you can do the exact same thing manually by just pressing the pedal a little faster and harder. )
Old Mar 17, 2012 | 08:57 PM
E-Ticket Ride's Avatar
I didn't realize that they had an application for the HR motor, thought only for the VHR motor (not that I would buy one).
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
AL8782
Oct 3, 2015 10:26 AM
dcsbh1
Oct 1, 2015 03:15 PM
wow600rr
Sep 28, 2015 11:50 AM
