Weird issue when accelerating
Old May 10, 2012 | 05:36 AM
Defratos's Avatar
You're Despicable
Exclamation Weird issue when accelerating
Hi guys,
A few weeks back I started to get a really odd problem,
Now this usually happens when I accelerate WOT from 2nd to 3rd (VDC is always off),
As soon as I shift to 3rd I get the usual small thump from shifting (normal nothing is different), but right after it shifts I get two scenarios:
- Usually my (handbrake light) switchs on for several seconds and then it'll switch of by itself.
- Second scenario is both my Slip light and my handbrake light switch on and stay on, I have to switch the car off and then back on for them to disappear.
This only happens when shifting from 2nd to 3rd and not always on WOT but on hard acceleration in general.
The only other thing that has been acting up in the car is I'm getting a weird metal rattle sound at around ~3,000 rpm (in any gear), it seems like either my exhaust is rubbing against something metal. Or that something is loose in the exhaust.
Last week I got my car up on the lift to check if there's anything loose but I can't find anything. Also there's nothing obvious about the exhaust rubbing against anything else to make the noise I'm getting.
The two above issues could be completely unrelated.
My main concern right now are the Slip light and the brake lights switching on when I shift from 2nd to 3rd.
Any ideas what this could be?
As for the metal rattle sound from the exhaust, could it be that the internals of the muffler on my Invidia have come loose?
It sounds very similar to when my Invidia HFCs had the membrane come loose, but now I'm running Sport Cats which are completely empty inside.
Any feedback of advice would be appreciated.
Old May 10, 2012 | 10:52 AM
Defratos's Avatar
You're Despicable
Leaving work today, got the exact same issue shifted from 2nd to 3rd on hard acceleration and got the usual sign:
sry about the shaky pic but you get the idea
and after 5 secs it vanishes (again my VDC is always off)
Old May 14, 2012 | 09:57 AM
aozmaxed's Avatar
I'm having this issue also, the Slip and initial Brake light comes on when upshiting my 6mt, so far at 40k on my G35S. Then the Brake light goes off always after a few seconds. I'm going to do a thorough check up of all my fluids first. And I'll confirm if only in certain gears. Following your thread, hopefully nothing to do with the LSD or VDC.
Old May 14, 2012 | 10:10 AM
kool_yaar's Avatar
normal occurrence with the G when your brake fluid level is low
Old May 14, 2012 | 03:58 PM
Defratos's Avatar
You're Despicable
Actually just checked it today and it's a bit low.
I can just simply top it up right?
Old May 14, 2012 | 04:15 PM
Defratos's Avatar
You're Despicable
Old May 14, 2012 | 06:28 PM
aozmaxed's Avatar
Make sure you don't have any brake system leaks, Find out why it's low first. In my case my brake pads are almost gone, causing the low fluid. If you need pad replacement, no need to top off because the fluid will be pushed back to the master cyl with the thicker pad install. Or, if you need a system flush, again no need to top off.
Thanks, kool_yaar, for the answer to this problem!
Old May 14, 2012 | 07:43 PM
Glover997's Avatar
Kool_yaar has been always supportive with his helpful comments
Thank you dear.
Old May 15, 2012 | 12:00 AM
vqsmile's Avatar
Yes, use DOT #3 or match whatever you have in it. WHenever you have your brake pads changed, you'll probably have to sip some out with a turkey baster though.
Old May 15, 2012 | 05:18 AM
Crespo's Avatar
I have similar issue
Old May 15, 2012 | 05:19 AM
Crespo's Avatar
but it happens during first gear...when I start the car, it seems like it shift at 20km/hr....but I know it didn't shift to 2nd....its really werid...I hope there is nothing wrong with the gearbox...I still love this car...put so much money into it for modifing...I don't want to sell it yet...I have 74165 kms on it now,
Old May 15, 2012 | 06:10 AM
Defratos's Avatar
You're Despicable
Very good point you make, I'll check them sometime this week but I'm pretty sure my front pads are ok, the rear pads would be up for replacement.
Thanks, I was going on the assumption that DOT 4 or 5 would be the way to go.
Can someone confirm which one it is? Dot 3? 4? or 5?
Old May 15, 2012 | 10:52 AM
vqsmile's Avatar
Typically on these cars, there is substantial pad life left beyond the point where additional fluid is needed. You can go ahead and top it off, just be sure and compensate for the extra fluid when you replace pads. This is SOP for a brake mechanic; you always check the status of fluid in the reservoir as you push the calipers back. If it's too full, you take some out.
To clarify my comment about brake fluid: the factory spec for our brake fluid is DOT #3, but if you have replaced it in the past with DOT#4, you should match it with what ever is in it rather than mixing two different specs. There is no reason to consider #5 or #5.1, as your car was previously filled with #3, you have ABS, and you don't race.
Old May 15, 2012 | 10:58 AM
Defratos's Avatar
You're Despicable
Thanks for the update
Old May 17, 2012 | 02:07 PM
Defratos's Avatar
You're Despicable
Well got around to changing my brake pads today, and yeah they were nearly done.
As soon as I installed the new ones the brake fluid level went back up to max, good thing to know I don't have any leaks.
Now I just have to see if I still get that light under acceleration.
