Throttle Lag
Old Nov 19, 2017 | 08:36 PM
  #31
Serge Mullen's Avatar
Thanks, will try that, car has been running really nicely for the past few months to.
I've had it on Castrol Edge Extended for the past 8K miles, oil is still reddish although definitely turning darker. Was considering getting post maf tubes but decided it's probably not worth it, spend the $$ on an Alutec strut bar instead, assuming I don't need to buy any parts to fix this issue.
Old Nov 19, 2017 | 09:32 PM
  #32
Well this is the state of my battery. Hadn't noticed it before, obviously a fair amount of sweat and grime around both poles.
Should I try cleaning it up and re-connecting or is this a sign of a battery on the way out and better to simply replace?
How many miles does an average battery last in a G
Attached Thumbnails Throttle Lag-img_20171119_211810-1-.jpg   Throttle Lag-img_20171119_211817-1-.jpg
Old Nov 20, 2017 | 02:42 PM
  #33
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
Battery is destroyed and leaking acid out of both posts, carefully remove and recycle it, clean the entire battery compartment with acid neutralizer being careful not to get electronic components like the IPDM wet.
Old Nov 20, 2017 | 04:37 PM
  #34
LoSt180's Avatar
Depending on driving habits, batteries typically last between 3 to 6 years. Usually any more than 5 years and you're really driving on borrowed time, lol.
Old Nov 20, 2017 | 11:55 PM
  #35
New Walmart battery is in. Now Voltage drops from 14.0V to 12.9V after just a couple of minutes.
Old battery has been relegated for use in my Civic which I'm selling, it still seems to work and is more than enough to start a 1.7L 4 banger..
Old Nov 21, 2017 | 08:59 PM
  #36
Well I'm not out of the woods yet.
Today it started raining lightly, I noticed my battery voltage at 13.7V for quite a long time, it finally dropped to 12.9V, but only for a few seconds, it then went back up to 13.7, indicating the alternator was having to continually charge it. It did this several times throughout the day, so it appears i have an electrical issue/battery drain somewhere, possibly only when driving in the rain.
The car starts fine, so I'm not sure if theres any problem while its sitting. Are there any common culprits or things I can check? Would a multi-meter help?
Old Nov 21, 2017 | 09:22 PM
  #37
theronz's Avatar
Or just put it in a Civic lol
For sale!
Old Nov 21, 2017 | 09:40 PM
  #38
On the next dry day I'll check it. If it stays at 12.8-12.9V for most of the time, it means i have a short somewhere when water is introduced.
Old Nov 21, 2017 | 10:02 PM
  #39
cleric670's Avatar
BANNED!!!
You should have 12.5vdc with the engine stopped, 13.5vdc with the engine running.
Old Nov 21, 2017 | 10:37 PM
  #40
You may want to check your actual voltages, you will find the voltage fluctuates while running if you own a V36 G35, and perhaps any vehicle.
Old Nov 22, 2017 | 10:58 AM
  #41
LoSt180's Avatar
Check your grounds. A lot of times people over tighten the negative terminal and it ends up stretching and being a little loose. Just verify everything is tight.
Old Nov 22, 2017 | 10:41 PM
  #42
If you do a search it looks like this issue is very common with some users reporting problems back in '08 in their first year of ownership with cars that have only 10K miles. Still unclear what the root cause is although it appears the Bose head unit/sound system is a culprit.
If you listen to a lot of music even at medium sound levels I can see it needing in the range of 350watts or more, so at 12V you're looking at 30amps drain on the electrical system just to power the stereo while driving. That will keep your alternator busy..
Old Nov 25, 2017 | 05:28 AM
  #43
sjwtriggerer's Avatar
I got my car back last weekend. The mechanic who screwed up the car took it to Infiniti. He claimed that they only had to "upgrade" the ECU.
I've been playing around with the DS and pseudomanual modes since I got it back. Even in DS, the car has some lag, but manually downshifting seems to solve the issue. So it looks like the problem is with the TCU?
Any updates, Serge?
Old Nov 25, 2017 | 11:43 AM
  #44
cleric670's Avatar
BANNED!!!
For shifting issues clean up the transmission grounds located at the front of the engine, bolted to the top middle of the timing cover. You will have two bolts with small gauge wire lugs landed there. Unbolt them, use a metal brush to clean any corrosion, apply anti-oxidation grease and reattach.
Old Nov 26, 2017 | 12:04 AM
  #45
The total loss of engine power I had looks like it was due to a bad connection caused by a fouled battery post terminal. Since replacing the battery over to a new one, car is running fairly good with voltage staying at 12.9 over the past few days (only reads 14.1 for a few mins immediately after startup).
I still do get the odd hesitation from time to time when applying 30-40% throttle. This is likely coming from the throttle body and will need to get cleaned at some point, probably at the same time I will also replace the plugs and clean the MAF sensors.
