2008 G35x - P0014 now P0011
Old Feb 18, 2020 | 10:23 AM
chris87's Avatar
2008 G35x
I have a 2008 G35x. About a year ago, my car stalled at low RPM (driving through a parking lot). I took it to my mechanic, and I don't recall what exactly he did. I thought the problem was fixed, but a few months later, it stalled again. I took it back, and they cleaned the throttle bodies. That didn't seem to help, and the problem became progressively worse. There is rough idling and frequent stalling at low RPMs. My check engine light came on with code P0014. I replaced the Camshaft Position Sensor, started the car, and the light immediately went out. It seemed to be running better, but not even 24 hours later, the light came back on. I now have code P0011, which from what I understand, is the intake solenoid. Is it possible that the solenoid is also bad? Why wouldn't the P0011 code have been triggered with the P0014? I did pull out the solenoid, and it appears that it may have been replaced with an aftermaket version (I have a feeling this what my mechanic changed originally, but I have to look at the paperwork). I usually use OEM parts, so I don't know if that could be the issue. I appreciate any advice, suggestions, etc.
Old Sep 10, 2020 | 06:52 PM
gc10's Avatar
Hello my car also has a p0014 code I would like to know if you got yours resolved and what did you do thank you.
Old Sep 10, 2020 | 06:53 PM
gc10's Avatar
Wesboyd18
Oct 31, 2017 12:16 AM
thew60
Sep 1, 2014 04:42 PM
ravibhangoo
Nov 10, 2012 01:44 AM
G:Drive
Jun 28, 2012 01:06 PM
