My engine won’t crank any suggestions.
Old May 10, 2021 | 01:00 PM
Kallai Brent's Avatar
Infiniti G35 coupe 6MT
So I was drifting in the rain and my right passenger side front wheel hub bearing ended up loosening and the car engine died. I tried to turn the car back on but no luck. I replaced the battery, alternator, cvv, crankshaft position sensor, and both camshaft position sensors. When I try to turn it on the rpms doesn’t move at all and it does a very slow crank.
Old May 10, 2021 | 06:30 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
For starters the feedback subforum specifically states NO CAR QUESTIONS, moving your thread to another sub forum.
Very slow crank is typically either the battery or the starter, just because you put in a new battery doesn't mean it was charged, it's VERY common for them to lose their charge sitting on the shelf.
Put on a battery charger and see if it will take a charge, this is a great time to clean up the battery cables.
If it still slow cranks it's probably the starter, disconnect the battery, remove the starter, take it down for a bench test and have them compare it to a new or rebuilt one off the shelf because it's hard to judge if it's actually hard starting just looking at a single unit.6
Old Jul 20, 2021 | 09:40 PM
Ponyryd's Avatar
G35x
Tough to tell since your description is fairly unclear, could be as simple as a starter, but you may have also flooded the engine with water and you likely jumped the timing chain or it may still have some water in it. If it’s a stick car you can try push-starting it, but I fear something more serious is happening her and you should have a shop look at it before wasting more money on parts.
Old Mar 16, 2022 | 12:38 AM
Nikki's Avatar
Manual/automatic transmission
200
2004 G35 won't start. Battery is fine checked fuses..They're fine. No water anywhere. Tried to rest ECU got nothing..throwing 0000 no code. HELP!
Old Mar 16, 2022 | 12:41 AM
Nikki's Avatar
200
Old Mar 16, 2022 | 07:34 AM
telcoman's Avatar
Veteran: Army
If your vehicle is cranking and not starting, check for spark. Do you have fuel in your tank?
Old Mar 18, 2022 | 12:16 PM
cleric670's Avatar
BANNED!!!
The gas gauge is prone to failing, add 1 gallon of fresh fuel and see if it starts.
The engine does CRANK yes? It just won't start?
Muzi Moh
Sep 3, 2023 08:09 AM
JamarcusOS
Aug 30, 2019 02:35 PM
snunez
Oct 27, 2018 03:29 PM
WalidG35
Aug 13, 2018 12:49 PM
