Installing Laser Jammer - Help:)
Old 05-25-2007 | 03:51 AM
BigNYDog3's Avatar
It does get pretty annoying but after awhile you get used to it, works well if driving half asleep, wakes you up as you get close.
Old 10-27-2007 | 06:44 AM
wpv123's Avatar
can you post pics of where you installed the jammers in the front grill?
Old 10-27-2007 | 09:42 AM
IvoryPearl07G's Avatar
-Pull down on the shifter boots plastic aluminum looking ring below the shift ****.
-put car in neutral
-pull the retaining clip off of the shift ****. pull straight back on it.
-remove shift ****
-get a suitable tool to get underneath the piece of console surrounding the shifter. the side that fits against the cup holder portion is best
-pry it up from the front, then the sides
-pull the console peice up a few inches and pull out straight towards the back of the car. it will pull out of the center dash portion
-unplug electrical connections and its yours to mess with.
R350k5
10-01-2015 09:41 PM
gatorglaze
09-10-2015 01:03 PM
SilverG123
Engine - Electrical
09-04-2015 02:12 PM
Quick Reply: Installing Laser Jammer - Help:)
