So I just took apart my radio in my G35x to hook up Sat. Radio and ever since I turned it back on, I can't get rid of the ! an Airbag flashing warning. I disconnected the battery for 15 mins and still no luck? Do I need them to reset it via the computer at the dealer?
i've been figuring this out too for the longest time.. someone please help.. i looked at the service manual and found no luck..
I have to bring the car in for an oil change soon, so I will ask them to fix it and why this happens.
I believe you can do it like this. I have an 04 coupe and it worked for me. Turn key on but dont start car, before light begins to flash, turn key back off. Repeat for a total of 10x and light should disapper.
Thanks! This worked. One issue, I still now have the ! on. I thought the ! was on because of the airbag warning, but I guess not. Any idea how to get rid of the !?
Just to follow up, the instrument stii lit up is the low pressure tire notification. Any ideas how to turn this off? My guess is they need to fix this via the computer?
Quote:
Recheck all the tire pressure and fill as necessary. Then drive for about a mile or 2 then it should disapper
Quote:
SELF DIAGNOSTIC PROCEDURE (WITHOUT CONSULT-III)
Without CONSULT-III
To start the self-diagnostic results mode, ground terminal of the tire pressure warning check connector. The malfunction location is indicated by the warning lamp flashing.
Erase Self Diagnosis
Without CONSULT-III
• In order to make it easier to find the cause of hard-to-duplicate malfunctions, malfunction information is stored into the control unit as necessary during use by the user. This memory is not erased no matter how many times the ignition switch is turned “ON” and“OFF”.
• However, this information is erased by turning ignition switch “OFF” after performing self-diagnostic or by erasing the memory using the CONSULT-III.
Thanks. I am little confused. In Laymans turns, what do I have to do to get this light off?Originally Posted by treacherous
SM says without Consult 3 you can turn light off by first activating diagnostic mode.SELF DIAGNOSTIC PROCEDURE (WITHOUT CONSULT-III)
Without CONSULT-III
Without CONSULT-III
What am I grounding? The switch in the picture or the connector at the terminal? I am confused about this...
I think the connector is above the av unit, anyone? What are those connectors that are connected above the a/v radio to the white plastic piece?
Simple fix.....Follow the turning the key procedure as described in the thread. One problem though...no key. Just use the push button start instead. Keep your foot off the brake which pressing the button will move the ignition to "on" without starting the car. Push again and it cycles off.
This works because I had the same problem back in November. Even the dealer didn't know how to do it.
Can u break down what I need to do exactly please? I tried the off and on thing 6 and 10 times. Any help is appreciated.
1.) turn ignition switch from OFF to ON.
2.) air bag warning lamp is on for 7 seconds and turns off, then turn ignition switch OFF within 1 second after the lamp turns off.
3.) after ignition switch is turned OFF, wait for more than 3 seconds.
4.) repeat steps 1 to 3 twice. (perform 3 times total.)
5.) turn ignition switch ON. (self-diagnostic mode turns to Diagnosis mode.)
Follow the push button instructions instead of the key I gave you in the previous response.
I tried 4 times total, 3 to go into diagnostic mode. One more time as described in your post. The tire pressure warning is still on.
No, that I got rid of. It's the low tire pressure warning. I am going to try grounding that switch probably tonight.
