How to remove 6MT shift knob?
Old Jun 3, 2007 | 10:58 AM
Li_Photo's Avatar
How to remove 6MT shift ****?
Could someone please tell me how to remove a 6MT shift ****? I have the most of the service manual, but it refers me to a section that I don't have (TM-18). Is the **** same as previous where it just screws off?
Old Jun 3, 2007 | 11:01 AM
filanj's Avatar
rotate counterclockwise
Old Jun 8, 2007 | 11:52 PM
damineg35's Avatar
When that doesnt work
Ok help, turnig isnt working. What know? any tips please?
Old Jun 9, 2007 | 07:26 AM
CleanDGc's Avatar
make sure u vice grip the shifter it should help.
Old Jun 9, 2007 | 09:39 AM
NewMexicoG's Avatar
If it's the same as the auto you pull the boot down and remove a clip. Then it just pulls off. I'm guessing that if it won't unscrew with regular pressure you're either a wuss or it comes off some other way. Try pulling the boot down and see if that helps.
EDIT I just checked the service manual. It says to pull up the console finisher (the boot is attached to it) and grab the shaft with a wrench and unscrew the **** as the last poster suggested.
Old Jun 9, 2007 | 10:04 AM
lowrider's Avatar
The Search Function is your friend:
https://g35driver.com/forums/showthr...****+****+glue
Lou
Danielek
May 1, 2022 01:28 PM
TwinTurboZ
19 Inch
Sep 26, 2015 06:11 PM
G35CO
Sep 4, 2015 09:27 AM
pasjr1972
Sep 1, 2015 10:17 PM
