Headlight replacement
Old Jun 15, 2007 | 11:43 AM
spacecowboy's Avatar
if i want to run 6 or 8k HIDs instead of the stock 4700k, do i need to chage the stock ballasts also? never had HIDs before, don't wanna act without knowing
Old Jun 15, 2007 | 01:59 PM
hyukki's Avatar
I don't think so...
Old Jun 15, 2007 | 02:19 PM
07ivory6MT's Avatar
Nope, no changes, just buy a pair of D2S "bulbs" and install em where the old ones were.
Old Jun 15, 2007 | 02:35 PM
recommendations where to get replacement bulbs? cheapest i could find was 150 a pair
Old Jun 15, 2007 | 05:42 PM
razo168's Avatar
kelvin or "K" relates to color temp.. applies strictly to bulbs.. you should NEVER change out your factory ballast because factory ballasts are the best ones you can probably ever get..
Old Jun 17, 2007 | 03:37 PM
kmuniz78's Avatar
Stocks are also 4300k, rather than 4700k. Also, when installing the HIDs, make sure you put them in properly; i believe the color stip faces down.
Old Jun 17, 2007 | 05:54 PM
HungNg85's Avatar
Make sure you do not touch the bulbs with your fingers. I doesn't like water, sweat, or salt. Will reduce bulb's life.
Old Jun 17, 2007 | 07:02 PM
JAYY-G35's Avatar
Can I Put Hid In My Fog Lights ? Can What Kind To Get To Match My Stock?
Old Jun 18, 2007 | 04:30 AM
07ivory6MT's Avatar
Yup, you sure can, but its illegal, get one of those conversion kits that replace the 9006 bulb with an HID bulb that plugs into a ballast and everything that comes in the kit is right there.. but HID fogs kind of defeats the purpose of fogs, the light will just refract the particles and blind you
Old Jun 18, 2007 | 01:25 PM
hyukki's Avatar
I want Range Rover HID's.
Those are the best looking HID's IMO.
Pure white FTW.
Old Jun 18, 2007 | 01:26 PM
hyukki's Avatar
What type of bulb is the fog?
Old Jun 18, 2007 | 02:05 PM
viguera's Avatar
I replaced my fogs with HIDs... haven't found a single state where putting HIDs in the fogs is illegal, but maybe I didn't look hard enough. Linkage?
Old Jun 18, 2007 | 02:25 PM
max2k1's Avatar
Just FYI -- but do realize that the light output of 8k is significantly lower than the stock. So it could impact night-time visibility.
Old Jun 21, 2007 | 11:10 PM
JAYY-G35's Avatar
SO WHAT ABOUT THAT LONG STRIP ON THE SIDE, I GUESS PEOPLE CALL THEM CITY LIGHTS. WHAT CAN I DO TO THAT ? I JUST WANT BRIGHT LIGHTS
Old Jun 21, 2007 | 11:31 PM
ttrank's Avatar
Grocery getter
Philips 6000k FTW.
You will loose a little (not much) output over the stock 4300k but the color gains are nice!
