Simplified Oil Change
Old Jul 3, 2007 | 03:23 AM
MR Bulk's Avatar
On my last 14 cars or so (really), I have always installed one of these:
http://www.fumotousa.com/
In fact there were a few cars in the past where we used to change the filter every Other time, so the in between oil changes were literally done in just a few minutes - open valve, drain out oil, close valve, refill, drive off. And no more searching through the hot oil for a dropped drain plug, worn plug/pan threads, etc.
I believe the part number for our cars is F-103, although I would recommend requesting the "N" version:
It has a small extension nipple on the drain port so you can slip a tube over it and direct the oil to an alternate drainage site (recycling box, etc.) which does not need to be placed directly under the vehicle.
Old Jul 3, 2007 | 03:28 AM
Alan's Avatar
oh cool! i would always worry a bit about it getting knocked off or something... seems like youve had good experiences with this!
Old Jul 3, 2007 | 03:32 AM
hai109's Avatar
Nice...Very interesting...
Old Jul 3, 2007 | 07:25 AM
Virus's Avatar
Interesting find. Have you ever experienced leakage?
Old Jul 3, 2007 | 10:38 PM
MR Bulk's Avatar
No leakage ever, it's all solid brass with a special tight-fitting nylon ball rotating seal and it's made in the same country as our cars.
As for having it accidentally knocked off, it depends on how the original drain plug is situated. On oil pans where the drain plug is at the very bottom or lowest point of the pan and facing stright down then yeah, you should be careful but on all of my cars (so far) the plug is located in a bend or cant in the bottom of the oil pan, therefore the Fumoto Valve is turned sideways and is never lower than the pan's bottom.
I have not removed the skid plate on my car to check on the plug location yet, but if it's anything like my '04 Altima 3.5 SE it should be good to go. I do plan on adding this regardless so checking the pan bottom shape is inevitable, probably right when I break 3,000 miles since the next service would be at 3,750 which gives me time to order the Valve.
Old Jul 4, 2007 | 06:27 PM
krazzyguju's Avatar
Well make sure you take some pictures for us when you do the install. I dont even want to start looking for that plug. The engine is just too sealed off but it would def. save alot of us time. Thats a pretty good idea though.
Old Jul 4, 2007 | 07:21 PM
GreenGoblin's Avatar
The goblin resurrection
looks good def a good idea
Old Jul 6, 2007 | 08:51 PM
805g's Avatar
anyone use the n version on the g yet?
do you think it will pose a problem (i'm lowered).
Thanks all
Old Jul 6, 2007 | 10:44 PM
rphman's Avatar
how much do they run
how much are these valves?
thanks
Wade
Old Jul 7, 2007 | 01:04 AM
MR Bulk's Avatar
I used an "N" on my slammed '06 Chrysler 300C and clearance was fine.
I believe I paid something like $20-$30 per unit in the past.
Old Jul 7, 2007 | 02:01 AM
Nissanfan84's Avatar
Where's the Pr0N?
where can I find one?
Old Jul 7, 2007 | 03:02 AM
805g's Avatar
come on bro,
from the op. what a NOOOOOOOB hahaha jk
Old Jul 7, 2007 | 04:22 AM
MR Bulk's Avatar
Actually there are also a bunch on ebay right now. Average price seems to be in about the $22 range.
Old Jul 7, 2007 | 05:13 AM
805g's Avatar
i tried emailing the company to see if they could do a group buy.
Old Jul 7, 2007 | 05:30 AM
ndlive's Avatar
cool i would be in if a gb was set up..
