Ds Mode
Old Aug 3, 2007 | 06:43 PM
BlkG35Sport's Avatar
So what's the history of the Infiniti / Nissans Auto transmissions (with lock shift feature). Some of the earlier model Q45 had major issues.
The last Nissan i owed was in 1988 (lol)
Old Aug 3, 2007 | 09:27 PM
logik05se's Avatar
wat exactly does the "locking" mean.
Old Aug 3, 2007 | 09:57 PM
don't know Dude. Heard someone else call it that.
Old Aug 21, 2007 | 06:04 PM
airhoppz's Avatar
anyone else able to explain the paddle shifters and DS vs. M mode? The dealer said the car always shifts on its own at a certain point - is that true for M mode? I thought the purpose of M mode was that the driver has to make all shifts.
Just wanted to clarify. Thanks!
Old Aug 21, 2007 | 09:14 PM
Garnet Canuck's Avatar
Traveling Administrator
If you are in manual mode, whether it be using the paddles or the shifter, it will only shift when you want it to. It will not shift on it's own in manual mode.
Old Aug 21, 2007 | 09:57 PM
MojoKidd's Avatar
I have noticed if your in M mode, the car will automatically shift to first gear if you come to a stop. I also noticed that you can use the paddles when the car is in D mode, but it will go back into D mode after a certain amount of time if you don't shift with the paddles.
Old Aug 22, 2007 | 09:07 AM
airhoppz's Avatar
That was all I needed to know...time to rock on with M mode when I get my G :-) ANY DAY NOW on my bank's car loan...
Old Aug 22, 2007 | 10:41 PM
G35Now!'s Avatar
Moderation-free
Yes - M mode will also shift down to 3rd once you reach a certain speed (think it's ~20). But as said, it will not shift up for you, even if you're bouncing off the limiter.
Old Aug 25, 2007 | 08:44 PM
Originally Posted by rocaveli
I shift back and forth between D, DS, and M like 1000s of times every time I drive pretty much
1000 times, wow you think the transmission is built for all that shifting?
Old Aug 26, 2007 | 09:55 PM
fecurtis's Avatar
I've yet to use DS mode. I haven't really done much heavy spirited driving.
Old Aug 31, 2007 | 12:48 PM
GPogi's Avatar
Just to clarify....in DS mode the shifter will shift on his own at a certain point...I know the manual mode does, I just want to make sure the DS mode you have the option of shifting on the fly + or - with the shifter or just leave in DS and it shift automatically at certain RPM.
Thanks,
gpogi
Old Oct 7, 2008 | 09:02 AM
Gabster's Avatar
Does DS mode improve the 0-60 time over Auto? i.e. from a full stop will the car launch noticeably quicker if I put it in DS?
Old Oct 7, 2008 | 12:00 PM
Csquared's Avatar
The Manual mode would not upshift for you, however it would down shift to 1 when you stop and also downshift a gear if rpm drops to a point where you will stall the engine.
Old Nov 13, 2008 | 12:09 AM
Slappy_G's Avatar
Thanks,
gpogi
Just to clarify, when you move the lever over to pop it into DS, you're operating in Drive Sport mode, which is still full auto. If you then tap-up or down on the shifter or hit a paddle, you're in Manual mode, which shows the gear number. The only way back to DS (I think), is to toggle over to D, then back to DS.
Old Nov 13, 2008 | 10:46 AM
  #30
ANMVQ's Avatar
Yes that is correct.. Does this locking thing have anything to do with my car stumbling all over it self at 2k and 75-100% of WOT from a stop on low roll..
master111
Sep 25, 2015 08:32 PM
invincible514
Sep 21, 2015 07:05 PM
Cbohannan101
Sep 12, 2015 10:32 PM
Albanian122
Sep 12, 2015 04:02 PM
FRUG35
Sep 11, 2015 03:07 PM
