an icon
Old Aug 25, 2007 | 12:09 AM
black07revolver's Avatar
Unhappy an icon
this icon appear in my car last night and i do not know what is the meaning
Old Aug 25, 2007 | 12:17 AM
izmir41500's Avatar
G35driver Addict
low tire pressure
Old Aug 25, 2007 | 01:05 AM
r u sure becouz i just checked the tire pressur and it gave me 28 lb so its low or its for somthing els
Old Aug 25, 2007 | 01:13 AM
SUB-ZERO's Avatar
I think it should be at 35 psi.
-SZ
Old Aug 25, 2007 | 01:17 AM
ok but why the pressure get low ??
and is there any deffirent between the psi and lb
tnxxxx SZ and izmir41500
Old Aug 25, 2007 | 03:32 AM
MR Bulk's Avatar
Slow leak maybe?
Old Aug 25, 2007 | 10:42 AM
SVLRx's Avatar
PSI and lb is the same thing, psi stands for pound per square inch, and you should be at 35lb/psi. You might want to check your tire for a nail stuck in there, causing a slow leak. could be a faulty valve.
Old Aug 25, 2007 | 12:19 PM
yes that what they told in the service and they need to restor the system if ther nothing wrong with tire or the valves
Old Aug 25, 2007 | 03:21 PM
G-Whizzer's Avatar
See if they'll do Nitrogen - seems to leak less and have some other benefits.
Old Aug 27, 2007 | 12:04 AM
RCK's Avatar
RCK
My G 35 Sport manual advises 33lb/psi on all 4 tires. But I do run at 34lb/psi. Why 35lb/psi? Like the ride that way?
Old Aug 27, 2007 | 03:19 AM
BlackGSedaN1027's Avatar
It's a bit firmer ride @ 35 psi. Personal preference, Im assuming
KruZZe
Feb 27, 2023 05:04 PM
NailBomb
Oct 28, 2015 07:53 AM
MThawkins86
Oct 24, 2015 02:07 AM
vQFamily
Sep 30, 2015 01:17 PM
TurTLe*
Sep 29, 2015 01:43 PM
