Removing shift boot/surround
Old Oct 19, 2007 | 07:50 PM
CFar's Avatar
I tried a couple times to lift up on the plastic surround that holds the boot to the console, but it didn't come up. I don't want to sound like a sis, but is that all we need to do to get the boot off, that being pull it up and off?
Old Oct 20, 2007 | 09:04 AM
IvoryPearl07G's Avatar
if you want to get the boot off, you will have to take off the whole surrounding portion that its attached too.
-Pull down on the boots plastic aluminum looking ring below the shift ****.
-put car in neutral
-pull the retaining clip off of the shift ****
-remove shift ****
-get a suitable tool to get underneath the piece of console surrounding the shifter
-pry it up from the front, then the sides
-pull the console peice up a few inches and pull out straight back out of the center dash portion
-unplug electrical connections and remove
now you can access the boot portion
hope it helped.....
Old Oct 20, 2007 | 09:26 AM
CFar's Avatar
thanks ill see what I can do
Old Dec 20, 2007 | 05:21 PM
NeverStock's Avatar
Shift **** Removal
Were you able to get the shift **** and boot off. I've got a 6MT also and am wanting to replace the stock shift ****. Is it as simple as stabilizing the linkage and then just unscrewing the ****?
Thx!
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
dcsbh1
Oct 1, 2015 03:15 PM
RWDguy4238
Sep 30, 2015 12:13 AM
blnewt
Sep 25, 2015 01:48 PM
