DIY for removing air filters?
Old Oct 25, 2007 | 07:13 AM
Pdubz's Avatar
Does anyone have a diy guide to removing air filters to replace front blinkers and fog?? help would be greatly appreciated.. thanks
Old Oct 25, 2007 | 01:14 PM
hyukki's Avatar
It's really easy.
You need to undo the screw that's holding the filter box to the tube. Disconnect the tube from the box and just pull straight up with a good amount of force.
And you're done.
Old Oct 25, 2007 | 07:14 PM
rupdog326's Avatar
Out of many - one people
Originally Posted by hyukki
It's really easy.
And you're done.
You missed a screw - the one that is attached to the engine compartment bracket.
Old Oct 26, 2007 | 03:30 AM
hyukki's Avatar
Yeah. I was gonna edit it but I forgot to.
Old Oct 26, 2007 | 05:18 AM
B L U E S L A T E's Avatar
Honda Accord
Easy 4 step for removing the box.
1. Remove the screw that attaches the actual air box.
2. Remove the MAF sensor.
3. Unscrew the bracket on the tube-throttle body.
4. Remove the hose next to the throttle body.
uh... 5. Remove the entire OEM intake assembly.
When you take out the box, you'll have to use a bit of force to lift it. It might feel like there is another screw that's holding the box, but there are none. Just pull it straight UP and it should just slide off. Oh, and of course, above steps applies on both sides.
GOOD LUCK!
Old Oct 26, 2007 | 05:23 AM
johnsonhuang's Avatar
careful of your MAF sensor though, u break one of those things. its quite a pricey part to replace.
Old Oct 26, 2007 | 08:54 AM
rupdog326's Avatar
Yea, I don't think it is necessary to remove MAF. I had to move the air intake boxes in order to replace the amber turn signal bulb with the PIAA mirror orange bulb.
Old Oct 26, 2007 | 02:10 PM
Honda Accord
Oh, I meant to just unplug it. My bad.
Old Oct 26, 2007 | 10:10 PM
hyukki's Avatar
GOOD LUCK!
The whole OEM intake assembly?
That's not necessary!
Tolboothwilley™
Exterior-Vendor
Jul 28, 2016 12:42 AM
Texasscout
Aug 29, 2015 07:36 AM
JoeMac
Aug 20, 2015 10:17 AM
justgotg35
Jul 19, 2015 12:33 PM
