2008 Infiniti G35 6MT dyno
5AT: 4th gear
6MT: 5th gear
It won't make a dramatic difference; probably anywhere from 2-7 hp.
Not sure if you will run into some problems with the speed limiter on the 6MT HR's though. Great numbers.
6MT: 5th gear
I know the Dyno I used cut off when going into 4th for whatever reason. The tech said the car (at least the A/T) has a cut off limit, which, for mine, was going into 4th, or around 4th.
what MPH is the speed limiter at?
They should have let off before they hit the REV limiter....if you hit SPEED limiter in 4th then I dont know what the hell that was all about...i've been up to about 110 in 4th..I THINK.
rezendvous420
May 31, 2020 01:26 PM
newbdriver01
Jul 15, 2015 06:10 PM
