Bulb size for 2007 G35
Old Nov 21, 2007 | 02:23 PM
stanfna's Avatar
I thought everyone may find this useful....
2007 INFINITI G35 (Sedan)
High & low beam headlamp
HID-D2S
Parking light
2827
Front turn signal
992 (7440A)
Rear turn signal
7440
Tail light
LED
Stop light
LED
High mount stop light
LED
Fog/Driving light
9006
License plate
168
Back up light
921
Front sidemarker
2827
Rear sidemarker
LED
Map light
DE3175
Dome light
DE3175
Step/Courtesy light
DE3022
Trunk/Cargo area
158
Per http://www.sylvania.com/ConsumerProd...RG-Results.htm
Old Nov 21, 2007 | 02:58 PM
rupdog326's Avatar
Out of many - one people
The dome/map, step/courtesy, trunk/cargo, front side marker, and license plate lights are all the same. I replaced mine with LED equivalent of 168/194.
Old Nov 23, 2007 | 12:48 PM
Pdubz's Avatar
ddo u kno where i can purchase a LED bulb to replace the "visor" light?
Old Nov 23, 2007 | 01:13 PM
rupdog326's Avatar
If you are talking about the "vanity mirror" bulb try here.
Old Nov 23, 2007 | 08:19 PM
airhoppz's Avatar
Any easy way to replace the license plate bulbs? I want to install some super whites similar to the IS350's license plate lights.
Old Nov 29, 2007 | 01:13 PM
NeverStock's Avatar
There are two individual bulbs above the license plate (each with their own housing) the housings simply pop out with a push-tab on one side and a fixed tab on the other. Just look above the license plate at an upward angle from the ground and you'll see them. I noticed how easy they were when my car was up on a lift at the exhaust shop :-) Just replaced mine last night along with a few other's on the car - got the cool white LED's - they look great!
Good Luck
Old Nov 29, 2007 | 02:55 PM
stanfna's Avatar
I am about to replace my tag lights as well.
did you have to disconnect the battery or pull a fuse before you did it?
Old Nov 30, 2007 | 11:34 AM
NeverStock's Avatar
Technically yes you probably should - but I didn't because there are just too many things programmed inside the car to bother with resetting (radio stations, seating memory, etc...) *Note: If you intend to reuse your OEM bulbs at a later date consider pulling them out with gloves on or some other means to keep finger oils off of the bulb glass as this will shorten their lifespan. Not a precaution needed when reinstalling the LED's.
Old Nov 30, 2007 | 11:53 AM
stanfna's Avatar
whoops...too late for using the gloves. i pulled the bulbs out last night with my fingers. ohh well...i am only using them for back ups when the LEDs finally go out....which i hope is not any time soon!!!!
Thanks.
Old Dec 1, 2007 | 09:39 AM
barrister89's Avatar
I'd sure like a brighter trunk light. Is it possible to find a brighter bulb?
Old Dec 1, 2007 | 01:20 PM
INDYG35S's Avatar
Where can the led bulb be purchased? I'm in Indianapolis and there doesn't seem to be ant place to find these. Is there any side affects by changing these plate lights. Don't want that. Is it really that easy and will it work without messing something else up. I do like the look.
Old Dec 2, 2007 | 12:17 PM
stanfna's Avatar
Old Feb 23, 2008 | 11:32 PM
cobugi's Avatar
Thumbs up
HID-D2S
Parking light
2827
Front turn signal
992 (7440A)
Rear turn signal
7440
Tail light
LED
Stop light
LED
LED
Fog/Driving light
9006
License plate
168
Back up light
921
Front sidemarker
2827
Rear sidemarker
LED
Map light
DE3175
Dome light
DE3175
Step/Courtesy light
DE3022
Trunk/Cargo area
158
I went thru probably more than 20 posts and finally found this.
Thanks
Old Feb 23, 2008 | 11:59 PM
B L U E S L A T E's Avatar
Honda Accord
This should be posted in the FAQ thread...
Shane, would you mind?
Old Jul 6, 2009 | 03:50 PM
smetoye1's Avatar
I know this is old but i cant find the bulb size for the visor mirror. i hate that yellow looking bulb. does anyone know?
