help with headlight light fuse
hey everyone, i was looking through the owners manual looking for where the fuses are, but the only one i could find was the interior fuses. Does anyone know where the headlight fuses are enclosed. thanks everyone !!!!!
As per the service manual...
Unit Location Fuse No. Capacity
Headlamp HI (LH) IPDM E/R #54 10 A
Headlamp HI (RH) IPDM E/R #55 10 A
Headlamp LO (LH) IPDM E/R #56 15 A
Headlamp LO (RH) IPDM E/R #57 15 A
Front fog lamp IPDM E/R #58 15 A
Parking lamp (also used as the front side marker lamp) IPDM E/R #52 10 A
• Tail lamp
• Rear side marker lamp
• License plate lamp
• Each illumination
IPDM E/R #53 10 A
Stop lamp FUSE BLOCK (J/B) #7 10 A
Back-up lamp FUSE BLOCK (J/B) #4 10 A
• Tail lamp
• Each illumination
IPDM E/R #53 10 A
• Tail lamp
• Each illumination
IPDM E/R #53 10 A
• Tail lamp
• Each illumination
IPDM E/R #53 10 A
Err... the IPDM is the "intelligent power distribution module", btw. It's the box under the hood next to the battery.
Originally Posted by xxgoldenaugxx
checked that one, but the owners manual did not label the head lights
If you need a better illustration, check the exterior lighting section of the FSM. Page 64 shows the fuses for the headlamps and page 153 has a good diagram of the IPDM itself.
Not the fuse box next to the battery... the IPDM. It's the other box next to the battery.
ohh nice nice,thanks viguera. i thought there would be another box with more than just interior lights.
If it's the arm or the shade then it's going to the dealer.
Micale757
Lighting
Apr 8, 2020 10:46 AM
