Map background color question
When I first picked up the car, I could have sworn that the map background color changed from light to dark when the auto-headlights came on. Maybe I was just so excited and confused with all of the new features that I missed it?
I've read the manual, I've read the navigation manual and I can't find anything regarding the auto setting for the changing between light or dark, only the push button to manually change it.
What am I missing?
What am I missing?
The navi background will automatically switch to a darker color when you headlights come on, and revert back to the brighter color when your headlights go off. I found that if you are driving with the headlights on and you push the manual button to make the background lighter, it "de-activates" the automatic changes (even if you turn the car off and restart it). By pushing the manual button again, it will "re-activate" the automatic changes.
If it's set to night when the headlights are on,or set to day when the lights are off... you're in Aotu mode and it should change automatically.
Otherwise, you're in manual mode and will need to hit the button once as LISI stated.
rezendvous420
May 31, 2020 01:26 PM
