Sub/Amp install in 07 Sedan
Old Jan 5, 2008 | 10:48 PM
Bilaal Porter's Avatar
here is where I bought the loc from, fast shipping good service:
http://www.electronicsbonanza.com/co...Go.x=13&Go.y=9
DOMO
Old Jan 6, 2008 | 05:38 AM
shoeless's Avatar
Originally Posted by Bilaal Porter
shoeless, I still use the factory bose amp, just use the loc for the signal to my own amp. What makes this re-q different from most loc(s) is the fact that it overrides the factory bass limit. I know alot of folks get the JL audio 500/1 amp & W3 combination (which is common) I am not rich, so I worked within my means and budget to get the sound I like.
Thanks. Did you replace the factory speakers or just add a sub? I've got a set of CDT comps for the front and a Boston G5 sub that I'm planning on running in infinite baflle from the rear deck, all driven with a 125x4 Eclipse amp.
Old Jan 6, 2008 | 11:04 AM
Shoeless, I am still running with the factory speakers but since sound proofing the doors, I realize that it would be a snap to add aftermarket speakers. The door speakers (front & rear) have a plastic baffle ring which screws into the door panel. with a lil ingenuity & MDF I think adding speakers should be no problem for you. I might replace mine in a few months, let me know how yours turn out.
Old Jan 6, 2008 | 02:29 PM
shoeless's Avatar
Will do. dependinbg on which model i get (base or bose) my install will have differing characteristics. It almost sounds like a bose replacemet would be easier using the LOC you linked to, as the wiring to the amp is already in the trunk. I may hit you up for that TSB link if I wind up getting the premium package.
Old Jan 9, 2008 | 12:51 PM
shoeless's Avatar
PM'd you
Old Jan 17, 2008 | 02:03 PM
stanfna's Avatar
hey guys...help us out over here in this post...
https://g35driver.com/forums/audio-video-electronics/197432-07-g-coupe-sedan-box-4080-course.html
we are trying to get 4080 to build us an enclosure!
Thanks!
Old Jan 17, 2008 | 02:12 PM
B L U E S L A T E's Avatar
Honda Accord
I contacted him, too, and he told me that he's not planning on building the boxes for the sedan for next few months. OH well...
Old Jan 17, 2008 | 02:19 PM
stanfna's Avatar
he posted this today...
https://g35driver.com/forums/showthread.php?t=197432
Old Jan 17, 2008 | 02:45 PM
_evilMonkey_'s Avatar
dam!!!! that is some nice system u got there Bilaal Porter!!!!! just wondering... how much?!?!?!?!?!?!??!
Old Jan 18, 2008 | 09:09 AM
shoeless's Avatar
I don't think BP's system should cost very much. He only added a sub and mono amp.
Old Jan 20, 2008 | 03:53 AM
TMP_35's Avatar
JL audio is coming out with the Flat sub that fit directly on the rear panel that require either no box or very very small box.currently I am using SEAS reference /mcintosh in my G and loving it.I have a small 8 in in the factory rear panel with a very small box that fit directly under the panel.
Old Jan 20, 2008 | 11:44 AM
stanfna's Avatar
can you post some pics?
Old Jan 22, 2008 | 06:56 PM
gymcshoe's Avatar
does anyone know the colors of the cables I'm supposed to tap before the Bose amp? I want the cleanest signal so I figure the way to achieve this is to tap the wires before the factory amp. And I'm assuming if I do this, I wont need an LOC or line driver correct? Has anyone done it this way with success? Thanks
Old Jan 22, 2008 | 08:26 PM
stanfna's Avatar
those of you who know more about how the Bose system actually works correct me if i am wrong...but i think you have to go after the amp because the amp actually does some sort of processing to the signal from the head unit. I am pretty sure we tapped mine after the amp.
Old Jan 22, 2008 | 08:28 PM
  #30
gymcshoe's Avatar
stanfna, did you use a LOC or line driver? do you know what color wires you tapped. I tapped wires before and after the bose amp and nothing is coming out of the amp/box.
