Rewiring My Tail Lights
I've decided that I want to rewire my tail lights so that when I signal, insteal of that little bulb flashing, I want me brake light to flash, just like the FX. Anyone know if this is possible? I took it to a aftermarket shop whre they do a lot of electronics installations and they were not sure how to do it. I thought it was a fairly easy thing to do. Any ideas?
If I get it to work, I'll let you know but I don't think it will be a DIY because I won't be attempting the work. I definitely want to pay someone to do it - don't want to mess around with it myself and screw something up.
Not sure how to wire it, but you will need a relay or something to that effect, your issue is when your headlights are on you'll need a relay to turn off the right or left brake light and switch into a signaling mode. Sorry i can't be of more help, but start thinking resistors, and relays.
Originally Posted by imminence
Are those light bulbs single or dual filament? Anyone know offhand?
I don't know about you guys, but I was never a big fan of how they did the turn signals on our car.
Originally Posted by cnugs127
Do you mean the tail lights? They are dual - low when the head lights are on and high when the brake pedal is pressed.
On another note, good luck with this project, I dont think its going to be easy at all.
Machine Head
19 Inch
Mar 16, 2016 08:55 PM
