Fender Liner Removal
Old Mar 16, 2008 | 09:05 PM
terrycs's Avatar
I pulled my front tire off to see what it takes to remove of the aft fender liner. There are about 6 plastic "fastners" that I am not familiar with that hold the liner in place. Does anyone know if they are re-useable? If so, how are they removed? I didn't want to just rip them out if they are not re-useable until I have replacements in hand.
I looked through the FSM and only found the exploded view picture with out any instructions.
TIA
Old Mar 16, 2008 | 10:13 PM
_evilMonkey_'s Avatar
are you talking about "fastners" that hold #5 and #6??
i took out the fastners from #5 area to change my corner light and didnt have any problem. i think i used flat head to pop it out. hope that helps...
Old Mar 16, 2008 | 10:23 PM
speedracerg35's Avatar
use a narrow flathead screwdriver to pop up the center insert (you do not have to pull the insert all the way out). once you pop up the center insert shaft, you can use your fingers to pull out the entire fastener. it is reuseable.
Old Mar 16, 2008 | 10:33 PM
terrycs's Avatar
Yup ... I'm trying to pull out item 6 so I can see if there is a harness back there for fender marker lights.
terrycs's Avatar
Thanks for the information!
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
g.spot
May 9, 2016 10:54 PM
DRG35R
Jan 31, 2016 07:14 AM
dcsbh1
Oct 1, 2015 03:15 PM
