Will 20"s fill the space?
Old Apr 18, 2008 | 09:48 AM
captnroger's Avatar
Hi all,
I'm looking to fill the gaps in my tire wells without lowering my 07 G35-S Sedan. I also am looking for new wheels/tires as I plan on using the factory rims for winter snow tires. Can I put 20s of this thing without issue? Will that successfully fill the gap in the wells without lowering? Any issues with rubbing?
Thanks all for your opinions.
Old Apr 18, 2008 | 11:29 AM
TheIvoryG's Avatar
Its all about offsets, so you'd have to post those to see if there will be any issues.
Short story is that they will fit, and they will fill the gap a little more depending on the tires you use, but with 20s the car won't look right if its not lowered in my opinion. The less rubber you have, the more the car needs to be lowered.
Just my opinion...
Old Apr 18, 2008 | 01:27 PM
hyukki's Avatar
If you think about it, if you want to fill the gaps, you will have to drop it no matter what.
If you put 20's on your car to fill that 2 inch gap, you're raising the car 2 inches. Sure it might fill the 2 inch gap but you'll look like a 4X4 or a lifted truck.
Old Apr 19, 2008 | 05:38 AM
Higuma's Avatar
Almost...
You can almost do it with 19's if you go for the right size...
Here's a link to my thread and the details on my 19's...
https://g35driver.com/forums/g35-sedan-v36-2007-08/209906-new-take-old-wheels.html
teaser pic...
Cheers,
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
6spdGspot
Oct 5, 2015 01:55 PM
wayneside
SouthEast
Sep 23, 2015 06:38 AM
