Pilot Bearing?
Old May 9, 2008 | 05:51 PM
Nismo86's Avatar
Pilot Bearing?
I told the dealer about the issue I was having with a clutch.. When the clutch is pushed in it in gear (going to shift or sitting at a light) or when I sometimes have it in no gear it would do the same thing (VERY rarely though) it makes some noise like some metal is hitting and spinning.
I was told it was the pilot bearing and that this is normal and has been doing since 2003 models..
Is this true? Sounds a bit weird.
Old May 10, 2008 | 12:46 AM
kool_yaar's Avatar
Yes sir, it is true. and i also suffered with these symptoms for about 6 months until i got my clutch recall done, through which they also gave me a free Clutch Kit new master cylinder,slave cylinder and an ecu update, since then i have had no issue with the clucth or the tranny.
I actully love driving it and the sounds are ALMOST nonexistant, i can only hear them when i really try to otherwise no more chattering as before, so look into the slave cylinder recall.
G/L
Old May 10, 2008 | 03:33 PM
Nismo86's Avatar
Anyone else have these problems?
Old May 11, 2008 | 12:26 AM
Chris G35's Avatar
I don't think have this issue but then again I have an 08, I do here a click sometimes when I depress the clutch, is this the sound you are talking about?
Old May 11, 2008 | 10:27 PM
Nismo86's Avatar
No it sounds more like metal hitting metal and you can feel it in the clutch pedal. Sometimes you can actually hear it too.
Old May 12, 2008 | 10:41 PM
Chris G35's Avatar
What I feel when I depress the clutch half way down and to the firewall is like the clutch is tight and makes a metal on metal rubbing sound that sounds like it needs to be lubed, not loud or anything but it is noticeable. Is this normal? (sorry to hijack your thread)
Approximately home many miles were on your car once you began to experience this problem?
Old Apr 30, 2010 | 01:55 AM
Jim Budrakey's Avatar
intermittant rotational rubbing noise
has anyone ever figured out what caused this noise? I just had my clutch replaced with an aftermarket flywheel, and my car started making this noise 2 days later. I brought it back and the shop replaced all of the clutch and bearing parts - and the noise again returned after about 2 days. Any insight would be great.
Dallsinghjr1
Sep 17, 2023 11:25 AM
Marlin84
Apr 1, 2020 12:52 PM
Claudiu
V36 Brakes, Suspension, Wheels & Tires
Mar 10, 2018 11:38 AM
AL8782
Oct 3, 2015 10:26 AM
gqraverice
20 Inch
Sep 29, 2015 05:39 PM
