Changing bulbs in headlight housing
Old May 15, 2008 | 03:35 PM
AlexF's Avatar
Lightbulb Changing bulbs in headlight housing
I'm planning on changing the headlight, parking and fog bulbs. Is the best way to do this through the wheel well lining or can everything be accessed from the engine bay? Also, will this void my warranty? thanks in advance.
Old May 15, 2008 | 04:44 PM
popnfresh's Avatar
wheel well is easier, even if you go through the engine, and remove the intakes etc
you will still need some small hands to do everything easily
if you throw some wierd bulbs in there it will void your headlight warranty, but affect nothing else
Old May 15, 2008 | 04:56 PM
AlexF's Avatar
I was looking at the DIY for the Phillips headlight bulbs, will this method give me access to the little parking lights as well as the fogs?
Jusseth
Sep 13, 2020 12:25 PM
as25656800
Aug 9, 2015 07:25 AM
neight
Aug 2, 2015 03:01 PM
EasySausage
Jul 20, 2015 03:56 PM
attarday
Jul 15, 2015 04:03 PM
