tips headlights + grill?
Old May 16, 2008 | 12:15 AM
g35hakop's Avatar
well im getting my headlight housing and grill painted on Monday so i needa to take it apart this weekend any tips? a little help i will appreciate thanks
Old May 16, 2008 | 12:23 AM
shabarivas's Avatar
where you @? pretty easy to do... lotsa clips... DIY... use search
Old May 16, 2008 | 12:25 AM
g35hakop's Avatar
im from LA cali
Old May 16, 2008 | 12:44 AM
shabarivas's Avatar
oh man... I am positive there is someone who can get that off in under 20 mins @ LA...
Old May 16, 2008 | 07:29 AM
paulg35s's Avatar
There is a DIY for the grille here:
https://g35driver.com/forums/v36-diy/204699-diy-grille-removal.html
As far as the headlights go, the bumper needs to be dropped. The headlights are held on by about 4 10 mm bolts I believe.
Old May 16, 2008 | 10:22 AM
g35_6gear's Avatar
https://g35driver.com/forums/v36-general-tech-questions/220667-headlight-housings.html
200 degrees for 10 minutes in the oven.
Old May 16, 2008 | 11:04 AM
TheIvoryG's Avatar
Post in your regional section...I bet there is someone there that can do it quickly for you too...
Old May 16, 2008 | 12:04 PM
g35hakop's Avatar
does the wheel have to come off so i can reach the headlight bolts?
Old May 16, 2008 | 12:54 PM
paulg35s's Avatar
i did it by just cutting the wheel all the way to one side and then the other to get to the bolts
Old May 16, 2008 | 01:14 PM
g35hakop's Avatar
is ur car dropped on 20's? cuz mine is and i dno if i can reach the bolts just by cutting the wheel to one side not enough clearance.
Old May 16, 2008 | 02:18 PM
paulg35s's Avatar
i did it on a stock g35x Just suck it up, jack up the car, put it on jack stands and go go go.
jeffbdye
Jun 1, 2018 03:51 PM
Picture Share
Feb 4, 2018 12:41 PM
Batfinity
Lights
Sep 27, 2015 12:29 AM
