For those using Mobil 1 Oil Filters...
Old May 29, 2008 | 05:06 PM
longbutthair's Avatar
I just changed my oil. I switched to Mobil 1 synthetic 5w-30. I also went with the Mobil 1 oil filter, M1-108. It seems smaller than the original Nissan one. Will this be an issue? Did I get the right filter?
-David
Old May 29, 2008 | 05:26 PM
oughttoreturn's Avatar
Yes it will be fine!
_________
2008 G35 journey5at ivory/stone+prem&sportpkg.
Old May 29, 2008 | 05:29 PM
Oh, thanks for the write up by the way. Awesome!
Old May 29, 2008 | 08:08 PM
kring's Avatar
yup, just fine with that filter, it's one of the best available on the market!
Old May 29, 2008 | 08:35 PM
Virus's Avatar
That's the correct filter. You could use the M1-110 which is slightly larger, but it has the same thread pattern and same bypass valve pressures.
f22raptor
Mar 18, 2016 08:50 AM
prinny
Nov 22, 2015 11:07 PM
mbe32
Nov 13, 2015 11:09 PM
9tray turbo
Sep 29, 2015 10:22 PM
