Sub question?
Sub question?
The dealership had to replace my Sirius Sat radio and antenna yesterday. I noticed that the rear sub isn't playing now, so I assume they forgot to reconnect it. How do I get to it?
There is a carpeted panel in the trunk underneath where the sub sits, it is held by 4-5 Push pins on the front and sides and velcro on the back, simply remove this and the panel comes off, then you will see the Sub with a socket that plugs into it.
If thats the problem you should be all set!
G/L
G/L
I know how to fix it, but I'm not going to waste my valuable time. The dealership is on the way to work and I'll drop it off and when the survey comes to the house I'm going to ding them for bad customer service as I always do.
JG_G35
19 Inch
14
Sep 19, 2015 09:04 PM
