grinding 6th gear
Old Jul 18, 2008 | 08:48 AM
  #31
Scooby24's Avatar
Originally Posted by Cali G
I'd imagine gear skipping is ok as long as you're pretty much matching revs with the next gear.
I.E. 1st > redline, 2nd > redline, pause and rpms drop to ~2,400 and you put it in 5th @ ~50mph or so.
You can also put GM Syncromesh in if your syncros are grinding and you can't get things fixed under warranty... it made all the gear grinding in 3rd gear in my old VW go away and is commonly used across various makes and models to solve grinding.
Be careful with Synchromesh. I used it in my WRX and it made the synchro grind go away but it's so thin it's not providing nearly the protection I'm comfortable with for the gears themselves.
I'm partial to redline shockproof lightweight. I used it in my STI and all synchros were happy and it's so thick, I felt the risk of slamming gears and high rpm clutch drops wasn't nearly what it used to be.
Old Sep 25, 2008 | 12:42 PM
  #32
McJay's Avatar
i had this problem in mine thankfully it was under warranty . NEW tranny, 6th gear sinc was gone. not done since.
Old Sep 26, 2008 | 04:54 AM
  #33
07-G35-MT/S's Avatar
New transmission here. We should do a new trans roll call.
magnetism80
Feb 1, 2019 10:00 AM
RichardP9
Drivetrain
Oct 26, 2015 11:25 PM
alinero718
Sep 27, 2015 09:35 PM
Since 1983
Sep 19, 2015 10:26 AM
UndyingDest
Drivetrain
Sep 7, 2015 12:49 AM
