Satellite on 07 and newer G35s?
If by "order" you mean from the factory / dealer, then no. The G35 was only offered with XM, and everyone I talked to said it would only work with XM. Luckily some of us don't listen very well
. You can order the parts you need for Sirius from Grubbs, and use this post for instructions on how to do it.
Takes anywhere form 30 minutes to an hour or two depending on your knowledge and where you run the antenna to.
Good luck.
. You can order the parts you need for Sirius from Grubbs, and use this post for instructions on how to do it.Takes anywhere form 30 minutes to an hour or two depending on your knowledge and where you run the antenna to.
Good luck.
laksjd84
Jul 24, 2015 05:12 PM
