help with offsets..
Old Jul 10, 2008 | 04:46 PM
MANSU_V36's Avatar
help with offsets..
does anyone kno if 20x9.5 +17 fronts 20x10.5 +13 rears would fit...on the 07+ sedans...
Old Jul 10, 2008 | 04:55 PM
g35_6gear's Avatar
Not even close.
Fronts in a 9.5" would be tight...maybe around a +40-45 offset required.
Rears in a 10.5" have been done but only in a higher offset....around +48
https://g35driver.com/forums/media-share-v36-sedan/231168-20x10-5-no-rubbing-4-inch-lip.html
Old Jul 10, 2008 | 05:19 PM
Wei's Avatar
Wei
only way i see it fitting is slamming the right, camber it out and some major fender pulling type of work
Old Jul 10, 2008 | 05:41 PM
terrycs's Avatar
Not unless you are going to be the first wide body sedan!
Old Jul 10, 2008 | 09:26 PM
MANSU_V36's Avatar
thanks for all your replys
what if i go 10.5 +40 with strecth tires
Old Jul 11, 2008 | 01:44 AM
Wei's Avatar
Wei
that i'd say would work (lowered and camber)
Old Jul 11, 2008 | 01:47 AM
Gdup35sedan's Avatar
ENVautoDetailing.com
you can do a 10.5+40 without stretching the tires if you drop the car (over and inch) and run around -1.8 rear camber. You can still run a 275/30 tire with those specs.
If you dont want to run that much negative camber then you can get a 255/35 tire and run -1.4 or so camber as long as you're dropped (over an inch)
-GP-
Old Jul 20, 2008 | 06:24 AM
n15m0's Avatar
Do the 04 and 07 sedans take similar offset and widths? ie do the both have similar guards and take the same maximum offsets?
Thks
toymachine2009
Jul 16, 2010 02:49 AM
cchaorule
Dec 2, 2008 03:41 PM
WinglessG
Dec 20, 2006 10:05 PM
