Fog light access
Old Jul 18, 2008 | 03:06 PM
sredish's Avatar
Fog light access
Where would the factory fog light be accessed in this picture, behind that rubber cap up to the right?
Old Jul 18, 2008 | 05:23 PM
SVLRx's Avatar
it would be on the FAR left...
Old Jul 18, 2008 | 05:30 PM
hyukki's Avatar
Easier way is to take off the filter assembly.
You just take off like two screws that are holding the filter in place and pull it straight up with a bit of force. You might wanna take the intake tubing out of the filter assembly first.
After you get the assemly out, you'll see it. You can't miss it. I think the plug was brown if I remember correctly.
Old Jul 18, 2008 | 06:08 PM
SVLRx's Avatar
yea, pretty much what i did. I put in HID fog's last week, just a 10mm screw for the air box, and another flat head screw for the intake tubing, and pull straight up. then reach in, and it's right there. The wires were kinda short though, so it made it kinda tough to work with.
Old Jul 18, 2008 | 07:14 PM
sredish's Avatar
I'm toying with the idea of some Injen intakes, so I might do it in conjunction with that.
Jusseth
Sep 13, 2020 12:25 PM
zoop425
Mar 29, 2016 05:51 PM
Freddy07g35
Sep 17, 2015 08:53 PM
LARA_G35
Aug 21, 2015 12:52 PM
attarday
Jul 15, 2015 04:03 PM
