JWT Pop v Injen?
Old Aug 4, 2008 | 03:58 PM
Beltran1129's Avatar
Thumbs up
Originally Posted by ugaexploder
Well, you're still losing money regardless if you're selling or keeping your stillen long tubes if you go through and get another intake system. The reason I say this is because you're not going to sell your stillen system for what you got it for, so automatically this is a loss.
Also, I don't remember reading anywhere that the Stillens gave a loss in HP. The only time I remember seeing anything about an aftermarket product giving a loss in HP is the Fujita system...and that was only from the technosquare ecu flash thread...
I Agree with this, Read the same thing..
Perosnally stillens have worked Fine With Me!?
Old Aug 4, 2008 | 04:32 PM
ugaexploder's Avatar
The only place I can see him getting this information about Stillen's losing hp would be from earth0...He used to have the stillen intakes and switched back to stock and he said from his "butt dyno" that the stock felt better...but by no means is this actual dyno testing results...so there is inconclusive evidence that the stillen's provide a dyno loss...
As far as we know, the only intake to give a loss is the fujita...so maybe you should reconsider keeping your Stillen intakes...I'm sure they don't give you a loss in HP
Old Aug 4, 2008 | 10:23 PM
silverG2007's Avatar
Originally Posted by sredish
the fujita on one particular dyno showed nearly a 10hp loss. true, the jwt uses a larger filter inlet but that's due to the flow enhancing venturi. if someone thinks that venturi is a gimmick, then look on virtually every carb.
regardless of the heat shields, they're all only going to do so much considering the throttle bodies have coolant running through them, they're only going to cool off so much and it's going to be minimal, but one difference is allowing for a more fluid flow and more proper inlet velocities which is what the venturis will do.
Interesting (about the TB having coolant running through them).
On my last car, a popular free mod to do was the Throttle body coolant bypass. Basically it was two plugs and a tube to bypass the TB. It keeps the TB from getting really hot which lowers intake air temperature, and makes more power.
It's probably only good for a few horsies..... but it's "free."
Anyone done something like this on a G35? Living in FL, I wouldn't have to worry about freezing temperatures.
Old Aug 4, 2008 | 10:31 PM
sredish's Avatar
there's been talk about it but most are concerned 1) about sensors in the TB reading a lower temp causing the ECU to compensate negatively and 2) the winter time some think there could be a problem with temps of some sort. Not really sure but I really don't see how it would hurt unless it screwed up ECU sensors, which the Cobb unit or something else should fix that. I like the idea of bypassing but don't want to be the guinea pig.
Old Aug 5, 2008 | 12:33 AM
kool_yaar's Avatar
+1000, but it would be a worthy mod with a tune for sure!
Old Aug 5, 2008 | 10:38 AM
sredish's Avatar
here's a 3rd party dyno on a coupe comparing the stock vs. JWT. runs were done before intake swap to obtain consistency, then the swap and retest. Says he's getting a mileage increase of 1 to 2 mpg as well.
http://myg37.com/forums/showthread.php?t=182789
Old Aug 5, 2008 | 01:39 PM
kool_yaar's Avatar
^ Nice update, i always wondered if it would help with MPG, all the more reason to get it, just cant wait to get it installed...
Old Aug 5, 2008 | 02:30 PM
G-perz's Avatar
Looks good. Interesting information.
Old Aug 5, 2008 | 02:35 PM
Well How about these!???
Will these fit the Sedan!? It says their for the 350z HR?
Pretty sweet Ones too!!
at MyNismo.com
Old Aug 5, 2008 | 03:12 PM
kool_yaar's Avatar
From having talked to many shops and distributors i have learned that though the engines are the same, some of the 350Z bolts on will not work on the G stritcly because of the room in the engine bay, with different angles and such, but you can always try if you want...
Old Aug 5, 2008 | 04:59 PM
1) IAT sensor (intake air temp) should only read a lower temperature if the air IS a lower temperature. That would be a good thing.
2) I live in Florida. Frozen TB wouldn't happen.
As far as I know, I don't think there are temp sensors that measure your TB temperature. I wouldn't see the point.
And yeah, I wouldn't want to be the guinea pig. But, I'm not worried about an extra few HP. For the guys with intakes and exhaust, it might be a worthwhile mod.
The only reason the coolant runs through the TB is to keep it from getting frozen and stuck in below freezing temperatures.
Old Aug 5, 2008 | 06:25 PM
sredish's Avatar
i've heard on the s2000 hondas, they've shown a 5hp loss from heat once the car's warmed up... after bypassing the TB, that 5hp came back, so in essence, it's a 5hp gain on a warm motor... we have two TB so I wonder how it'd help there.
Old Aug 5, 2008 | 06:28 PM
come on sredish, be our guinea pig!
Old Aug 5, 2008 | 08:59 PM
sredish's Avatar
honestly, i'm not familiar enough with the motor stuff on out cars to know how to do it, otherwise, I'd probably consider trying it.
Old Aug 5, 2008 | 10:59 PM
  #30
I don't see how it could hurt anything. And it'd be easily reversible and only cost a few bucks in parts to do.
Who's our pig?
