New 08 G35 mod help?
Old Sep 15, 2008 | 05:10 PM
g35 chippie's Avatar
Originally Posted by gcg35
you can have aftermarket tint installed on front windows. just as long as 70% of light passes through.
Wrong. Find for me in this section where it says 70%. It says 88%, but must be clear and colorless AND has to meet all of the other requirements. Urban legend strikes again.
26708. (a) (1) No person shall drive any motor vehicle with any
object or material placed, displayed, installed, affixed, or applied
upon the windshield or side or rear windows.
(2) No person shall drive any motor vehicle with any object or
material placed, displayed, installed, affixed, or applied in or upon
the vehicle which obstructs or reduces the driver's clear view
through the windshield or side windows.
(3) This subdivision applies to a person driving a motor vehicle
with the driver's clear vision through the windshield, or side or
rear windows, obstructed by snow or ice.
(b) This section does not apply to any of the following:
(1) Rearview mirrors.
(2) Adjustable nontransparent sunvisors which are mounted forward
of the side windows and are not attached to the glass.
(3) Signs, stickers, or other materials which are displayed in a
7-inch square in the lower corner of the windshield farthest removed
from the driver, signs, stickers, or other materials which are
displayed in a 7-inch square in the lower corner of the rear window
farthest removed from the driver, or signs, stickers, or other
materials which are displayed in a 5-inch square in the lower corner
of the windshield nearest the driver.
(4) Side windows which are to the rear of the driver.
(5) Direction, destination, or termini signs upon a passenger
common carrier motor vehicle or a schoolbus, if those signs do not
interfere with the driver's clear view of approaching traffic.
(6) Rear window wiper motor.
(7) Rear trunk lid handle or hinges.
(8) The rear window or windows, when the motor vehicle is equipped
with outside mirrors on both the left- and right-hand sides of the
vehicle that are so located as to reflect to the driver a view of the
highway through each mirror for a distance of at least 200 feet to
the rear of the vehicle.
(9) A clear, transparent lens affixed to the side window opposite
the driver on a vehicle greater than 80 inches in width and which
occupies an area not exceeding 50 square inches of the lowest corner
toward the rear of that window and which provides the driver with a
wide-angle view through the lens.
(10) Sun screening devices meeting the requirements of Section
26708.2 installed on the side windows on either side of the vehicle's
front seat, if the driver or a passenger in the front seat has in
his or her possession a letter or other document signed by a licensed
physician and surgeon certifying that the person must be shaded from
the sun due to a medical condition, or has in his or her possession
a letter or other document signed by a licensed optometrist
certifying that the person must be shaded from the sun due to a
visual condition. The devices authorized by this paragraph shall not
be used during darkness.
(11) An electronic communication device affixed to the center
uppermost portion of the interior of a windshield within an area that
is not greater than 5 inches square, if the device provides either
of the following:
(A) The capability for enforcement facilities of the Department of
the California Highway Patrol to communicate with a vehicle equipped
with the device.
(B) The capability for electronic toll and traffic management on
public or private roads or facilities.
(c) Notwithstanding subdivision (a), transparent material may be
installed, affixed, or applied to the topmost portion of the
windshield if the following conditions apply:
(1) The bottom edge of the material is at least 29 inches above
the undepressed driver's seat when measured from a point 5 inches in
front of the bottom of the backrest with the driver's seat in its
rearmost and lowermost position with the vehicle on a level surface.
(2) The material is not red or amber in color.
(3) There is no opaque lettering on the material and any other
lettering does not affect primary colors or distort vision through
the windshield.
(4) The material does not reflect sunlight or headlight glare into
the eyes of occupants of oncoming or following vehicles to any
greater extent than the windshield without the material.
(d) Notwithstanding subdivision (a), clear, colorless, and
transparent material may be installed, affixed, or applied to the
front side windows, located to the immediate left and right of the
front seat if the following conditions are met:
(1) The material has a minimum visible light transmittance of 88
percent.
(2) The window glazing with the material applied meets all
requirements of Federal Motor Vehicle Safety Standard No. 205 (49
C.F.R. 571.205), including the specified minimum light transmittance
of 70 percent and the abrasion resistance of AS-14 glazing, as
specified in that federal standard.
(3) The material is designed and manufactured to enhance the
ability of the existing window glass to block the sun's harmful
ultraviolet A rays.
(4) The driver has in his or her possession, or within the
vehicle, a certificate signed by the installing company certifying
that the windows with the material installed meet the requirements of
this subdivision and identifies the installing company and the
material's manufacturer by full name and street address, or, if the
material was installed by the vehicle owner, a certificate signed by
the material's manufacturer certifying that the windows with the
material installed according to manufacturer's instructions meets the
requirements of this subdivision and identifies the material's
manufacturer by full name and street address.
(5) If the material described in this subdivision tears or
bubbles, or is otherwise worn to prohibit clear vision, it shall be
removed or replaced.
Old Sep 15, 2008 | 05:28 PM
G35plusKB24's Avatar
oh...i was lookin at this site when i read 70%
http://www.tintcenter.com/laws/CA/
it was the first ste that came up on google lol
thanks for the headsup...but where im at i see so many cars with a front side window tint, it seems common...many cars i see have a tint on the front side windows...too many to be counted
Old Sep 15, 2008 | 09:33 PM
gcg35's Avatar
[SIZE="2"][QUOTE=g35 chippie]Wrong. Find for me in this section where it says 70%. It says 88%, but must be clear and colorless AND has to meet all of the other requirements. Urban legend strikes again.
[SIZE="4"]since you want to be a jerk about it.. right back at you:
http://www.dmv.ca.gov/pubs/vctop/d12/vc26708.htm (towards the bottom)
(2) The window glazing with the material applied meets all requirements of Federal Motor Vehicle Safety Standard No. 205 (49 C.F.R. 571.205), including the specified minimum light transmittance of 70 percent and the abrasion resistance of AS-14 glazing, as specified in that federal standard.
the 70% i quoted refers to the total light transmission.. which is glass + tint. you usually can't do 70% tint because the glass itself has a slight tint to it (sometimes). if you want to be really careful.. don't tint your car. or just go to a reputable shop and ask for cali legal tint.
on my other car, i have cali legal tint that has been certified from llumar on my front windshield and front side windows. so yes, i do happen to know that you CAN tint your front windows .. though it really isn't very dark.. but does keep the car quite a bit cooler. didn't want that for the g though cuz it just didn't look as nice with a black car.
http://aterrifictint.com/
here is where i went in oc. a little pricy but they do laser cut. and they're great. again, they certify for front windows if you do the uvshield which isn't dark.. but cuts down on heat.
Old Sep 16, 2008 | 12:20 AM
I wasn't trying to be a jerk. Simply educating. Many people think you can slap on %70 tint and all is well with the world. It's simple reading comprehension. I pull my info from here (and the 80+ hours of Vehicle Code training at the Academy not to mention experience on the job and in court):
http://www.leginfo.ca.gov/.html/veh_..._contents.html
You only posted ONE of the requirements for 'legal' tint. There are five requirements that have to be met. Again, it has to be clear and colorless. Just like it states in (d). As far as your front window 'tint':
windshield
the windshield.
If you look at your windshield, there is usually a mark towards the top. That is the lowest you can have your tint.
netcbc
Exterior - Body Parts CDN
Aug 21, 2015 09:50 AM
laksjd84
Jul 24, 2015 05:12 PM
sick_sixspeed
Jul 21, 2015 01:59 PM
Tony_Me22
Jul 21, 2015 08:42 AM
Tony_Me22
Jul 17, 2015 06:30 PM
