MagnaFlow resonator replacement only?
Old Sep 29, 2008 | 11:48 AM
Glockz's Avatar
I must be search challenged....I thought there was a thread awhile back that discussed replacing the stock resonator with a Magnaflow. Anybody have any experience with this? I know just removing resonator sounds horrible...too raspy for me. Any input would be much appreciated.
Old Sep 29, 2008 | 12:00 PM
Csquared's Avatar
I haven't read one where they just replaced the resonator but sredish did do a magnaflow resonator and mufflers. I'm sure he'll chime in or something. I'm thinking of possibly just doing magnaflow mufflers.
Old Sep 29, 2008 | 12:13 PM
cremaster's Avatar
there was one dood who changed out his oem resonator off his 06 sedan and put a magnaflow resonator/muffler in place of it. was it that thread?
Old Sep 29, 2008 | 12:26 PM
sredish's Avatar
here's what I used,
http://www.planetmagnaflow.com/shop/...14385-330.html
but the thing is, the stock piping is 1.5" or something like that. it's small, so to use that resonator, you'd be going from 1.5" to 2.25" back to 1.* after the resonator. The stock Y pipe is the holdup. So, if you were to use this setup, i'd have a muffler shop install this resonator using 2.25" pipe from the cat flange to the resonator then whatever you want there; probably stepping back down into the exhaust pipe.
another alternative is to use some smaller dual bullet mufflers more matched to the car's pipe diameter. I'd still come all the way back from the cat flange to eliminate the stock y-pipe.
http://store.summitracing.com/partde...5&autoview=sku
It's a 1.75" in/out single, it's outside dia. is 3.5" so it'll fit good with two in there, similar to stock mounting.
Old Sep 30, 2008 | 11:23 AM
Glockz's Avatar
thanks sredish....I love the way your car sounds btw! I'm just looking for a low buck way to make it sound a little more aggressive. I'm going to look into the options you suggested. Thanks again!
Old Sep 30, 2008 | 11:33 AM
sredish's Avatar
thanks. and i think the car has gotten just a smidge louder since they've broken in. but, i do like the way it sounds, makes it hard to keep my foot out of it... lol
jsimonk
Dec 22, 2023 03:49 PM
poktanG35
Engine - Exhaust
Oct 26, 2015 03:32 AM
miata007
Aug 17, 2015 04:36 PM
Cam_Cooper3
Intake & Exhaust
Aug 10, 2015 07:04 PM
