How wide can I go?
Old Oct 13, 2008 | 04:26 PM
SOUPG35s's Avatar
How wide can I go?
How wide can I go on stock G35S rims? Does anyone have picks of wider tires on stock rims? Thanks
Old Oct 13, 2008 | 05:42 PM
terrycs's Avatar
https://g35driver.com/forums/g35-sed...ims-tires.html
Old Oct 13, 2008 | 08:05 PM
LOW2000's Avatar
I was wondering the same thing, the section width of our tires is definitely narrower than the width of the rim. I was thinking of going up one size in section width and down one in aspect ratio to maintain approximately the same sidewall and overall height so the speedometer and ABS/VDC are not affected.
Old Oct 13, 2008 | 09:43 PM
Scooby24's Avatar
He's asking how wide on STOCK wheels, not aftermarket.
I remember seeing someone who plus sized the tires.
235/50/18 and 255/45/18 a I remember.
https://g35driver.com/forums/tech-07...new-tires.html
Old Oct 13, 2008 | 11:59 PM
terrycs's Avatar
sorry, my bad.
Old Oct 14, 2008 | 08:24 AM
snowcrossmxz's Avatar
u can go 245/45 F and 275/40 R
Old Oct 17, 2008 | 01:09 AM
LOW2000's Avatar
I was thinking about this more, on my truck I have 20x8" rims and run a 275/45/20, our rears are 8.5" rims (on the sport), so you could run at least a 275 out back assuming there are no rubbing issues in the wheel well.
Old Oct 17, 2008 | 08:02 AM
thats a good point, BUT. ur truck has 45 series side walls, which means the side wall is taller, which translates to more stretch between the tread and bead.
275/40 on an 8.5 rim is 1/2 an inch off, the manufacture recommends at least a 9 inch wheel for that tire.
it will fit, i have done it. but ur just about at the limit.
jeffbdye
Jun 1, 2018 03:51 PM
carid
Aug 22, 2016 01:34 AM
alexbenz
Sep 26, 2015 11:30 AM
bananax
Wheels & Tires CDN
Sep 10, 2015 06:14 PM
