Noise between Wiper blades and front Glass
Old Nov 19, 2008 | 09:43 AM
highend's Avatar
How to resolve Noise between Wiper blades and front Glass. Very terrible sound. 3000 miles only.
Old Nov 19, 2008 | 09:52 AM
tg1234's Avatar
Have you applied anything on the windshield? Or maybe your dealer when they detailed your car? I would start with just cleaning the windshield with windex and clean the blades with soap and water to see if it makes a different.
To my experience 20 years on the road. My g's wiperblades are the best I ever had. On my 07 around 20 months and they were still awesome.
Hope this helps.
tg
Old Nov 19, 2008 | 10:08 AM
highend's Avatar
Hope this helps.
tg
Thx for reply. I will defiantly try to day Windex and soap. For sure was nothing apply from me or from dealer to the windshield.
I verify the problem from the first day, noise.
Old Nov 19, 2008 | 10:13 AM
express705's Avatar
rubbing alcohol might recondition the blades on the wiper also.
Old Nov 19, 2008 | 10:38 AM
highend's Avatar
Thank you,
Will try this method also. Somebody can explain from where and how that problem begins? May that issue link to Wiper Arm?
Old Nov 20, 2008 | 04:56 PM
Triton3.5's Avatar
I agree with TG, this car has maybe the best wiper system i have used, I also have Diamon-fusion aplied to mine from the dealer, so my cars glass is even smoother than new cars..... so its NOT the wiper motor then? regards
Old Nov 20, 2008 | 08:23 PM
JSG's Avatar
JSG
My stock wiper blades chattered like crazy. I tried RainX, keeping them clean, etc to no avail. Finally just bought a good set of Bosch wiper blades and problem solved. Maybe I had a defective set to start with, but it was very annoying.
Old Nov 28, 2008 | 12:02 PM
almatti's Avatar
Express705 must be an Old-Timer like me..... Rubbing alcohol to clean the wiper blades ususally does the trick, unless the rubber has been damaged. The rubber oxidizes from the acid rain. I garee with others, the wiper baldes and wiper system is probably best I've had compared to all the cars over the years, IMO.
Z1Motorsports
Suspension-Vendor
56
May 31, 2020 01:56 PM
rezendvous420
May 31, 2020 01:26 PM
MyfistYourFace
Aug 8, 2015 11:58 AM
mcneil_g35
Aug 5, 2015 12:03 PM
rping
Jul 26, 2015 09:53 PM
