Motor Oil on Air Filter
Old Jan 4, 2009 | 04:46 PM
Rizzagt22's Avatar
I just got done cleaning my Air Filter(s), and I when I finished cleaning the passenger side filter using high pressure air, I noticed there was motor oil all over my hand. Is this normal? I was holding the filter with my palm facing the side of the filter that is facing the throttle body. I need your input GDrivers
Old Jan 4, 2009 | 06:36 PM
4 Door Skyline's Avatar
I dont think its motor oil ....i think it might be some lube around the rubber edges of the filter....I havent changed mine out yet as I only got like 500 miles on mine, but I think I remember when I swapped out my stock paper filter in my 05 that it had some kinda grease on it.....
Is the "oil" on the filter itself or on the surrounding rubber? if its on the paper filter then theres something to worry about if not then I think its just the lube which is harmless
Old Jan 4, 2009 | 06:58 PM
Rizzagt22's Avatar
Its on the OEM Filter and partly surrounding the rubber, but the majority is on the filter.
Old Jan 4, 2009 | 08:46 PM
Rizzagt22's Avatar
According to Mike at Riverside Infiniti the OEM Air Filters come pre-oiled. That explains why when I took out my filters to clean them while the motor was still warm the oil was exposed by using high pressure air to clean out the air filter.
Old Jan 5, 2009 | 07:29 PM
Good to know....I didnt know the oem filters came oiled!!
redonblack35
Accessories
19
Feb 13, 2016 11:19 AM
derres
Aug 28, 2015 03:27 PM
JoeMac
Aug 20, 2015 10:17 AM
justgotg35
Jul 19, 2015 12:33 PM
