ground loop isolator
Old Jan 27, 2009 | 09:33 AM
shoeless's Avatar
I've had an LOC and external amp in my car for about 6 months. Recently, that old "whizzing" noise has started to show up - not just if I use an Ipod, but through the radio as well. Is it safe to use a ground loop isolator between my LOC and my amp. Second question is will it do any good?
Old Jan 27, 2009 | 11:22 AM
E-Ticket Ride's Avatar
Make sure your ground point is good, and that the paint under the eye loop you're using is scraped away. Also, make sure the metal is solid and not thin.
A ground loop is fine and won't cause any problems (use as the last resort). Most are in-line and go between the LOC and the amplifier via the RCA cords.
Old Jan 27, 2009 | 12:29 PM
shoeless's Avatar
Thanks. The ground is good. Just checked it yesterday. Can't figure out why the noise just started (and wasn't there for six months), but just wanted to make sure the isolator wasn't going to cause a problem in and of itself. Just a question, why would it be a last resort? Is there some inherent problem with using one?
Old Jan 27, 2009 | 02:23 PM
No, last resort meaning after you check the grounds, and even try a new grouding point. Plus, you have to lay out the cash for one, versus trying the grounds.
Old Jan 27, 2009 | 05:03 PM
shoeless's Avatar
Cool. Got it. Already had the GLI laying around, so no worries.
Marlin84
Apr 1, 2020 12:52 PM
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
prinny
Nov 22, 2015 11:07 PM
JustinMKN1
Sep 18, 2015 03:40 PM
