Window auto up not working
Old Jan 31, 2009 | 05:03 PM
jojo35's Avatar
Ok, heres a wierd situation. After having nissan fix my passenger side front fender/bump/headlight, the passenger door window "auto up" does not work on both the driver side switch and on the passenger side switch. All other windows work as they should, auto up + auto down. The window still opens and closes as it should, but one has to manually hold down/up to operate the window.
My question is, does this come from removing the door's internal connections? if not, can one do a hard reset of the feature?
(Solution Found)
Done by holding down for 5 seconds and up for 5 seconds
Old Jan 31, 2009 | 06:48 PM
earth0's Avatar
they ploblably unplug the negative battery before doing a job.That may be the season. Try to reset by pressing your driver window down in half and press all the way up.continue holding for 5-7 second and that's it!!
Repeat the same thing with every window.Hope it's help!!!
Old Jan 31, 2009 | 07:07 PM
erklep's Avatar
+1 that will fix you right up
Old Feb 1, 2009 | 10:32 AM
bmfgsxr's Avatar
there is a reset for it as mentioned.. run a search it is covered thoroughly how to do it.
mike730
Jan 12, 2018 04:25 PM
joedaddy1
Jul 28, 2015 02:58 PM
will091195
Jul 27, 2015 09:19 PM
apintojr
Jul 23, 2015 10:52 AM
attarday
Jul 15, 2015 04:03 PM
