Torque #'s anyone?
Old Feb 20, 2009 | 01:16 PM
soundmike's Avatar
Torque #'s anyone?
I've scoured through the FSM (or at least i think it's the complete book) and couldn't find the torque #'s for tightening the suspension and/or brake bolts when reassembling.
Would it be safe to follow that from, say, a Maxima? (My old car, for which i have the #'s for). I'm not a fan of "as tight as you can"
If anyone has the actual numbers, or a good ballpark range, i'd truly appreciate it.
Thank you.
- Mike
p.s. I'll be swapping suspension components and possibly brake parts.
Old Feb 20, 2009 | 01:31 PM
AesonVirus's Avatar
I just replaced my rear pads and I also was unable to find torque #'s for the caliper bolts.
I had to go with "Really friggen tight", but I'm also interested in a source for finding this sort of info.
Old Feb 20, 2009 | 09:01 PM
G35_OH's Avatar
Have you downloaded the Infiniti Service Manual? It's broken up into multiple PDF files. The one labeled BR.PDF is for the brakes. Look at the diagrams in that document and you'll see little wrench symbols which represent the torque specification. For example, on page 42 you'll find the diagram of the front disc brakes. Look at the diagrams in FSU.PDF for the front suspension and RSU.PDF for the rear suspension.
Old Feb 20, 2009 | 09:30 PM
E-Ticket Ride's Avatar
Here's the link for anyone interested:
http://psedog.com/cars/fsm/g35/sedan/2007/
Old Feb 20, 2009 | 09:34 PM
soundmike's Avatar
Are those what they are? LOL.
Okay, i'm looking at FSU-19. There are three sets of numbers after the wrench icon, "59.5 (6.1, 44)" for example. I'm guessing the first number is the torque rating, but what are the other two?
Thank you.
Old Feb 20, 2009 | 11:55 PM
G35_OH's Avatar
They're all torque specifications. Your example would be 59.5 Nm OR 6.1 m Kg OR 44 ft lb. All the same torque, just listed on different scales.
Old Feb 21, 2009 | 06:51 AM
soundmike's Avatar
Thanks!
frankywashere
Sep 2, 2015 01:22 AM
yosip1115
Aug 26, 2015 10:46 AM
Mattdi
Aug 23, 2015 11:27 PM
Raven7
Aug 14, 2015 04:40 PM
Ray Feta
Aug 13, 2015 11:40 PM
