incabin air filter question
Old May 11, 2009 | 12:08 AM
puga's Avatar
Can someone please school me on what the purpuse of the incabin filter? I have an 07 journey with 31k miles. I think its time to replace it. Is there a DYI video or instructions on how to do it? What happens if the filter doesn't get changed?
Old May 11, 2009 | 01:31 AM
yarrh's Avatar
All I can think of is poor air flow and in extreme cases, your ac compressor will freeze over
Old May 11, 2009 | 02:00 AM
mw08G35S's Avatar
it also cleans the air coming into your car. allergens, dust, dirt, smells. etc.
should change it every 15k or so. moisture develops in the filter from the a/c system (normal air is moisture rich) can develop mold, and decrease the performance of the filter.
we've got nice a/c systems. keep it working well cause warranty doesn't cover poorly maintained systems... unfortunately.
Old May 11, 2009 | 08:28 AM
Cabad85's Avatar
^+10000!
there is a DIY video somewhere, maybe on youtube. basically you just need to disassemble and remove your glove box to access and replace the in-cabin filter. i changed mine at 15K as well.
Old May 11, 2009 | 01:57 PM
drewm's Avatar
Link to Replacement
http://www.infinitihelp.com/diy/gsed...eplacement.htm
Old May 11, 2009 | 02:04 PM
dohturdima's Avatar
^ agree with above infinitihelp.com instructions - one thing that's not mentioned is that you should remove the 2 plastic trim pieces (one below the glove both, one directly to the right). Both trim pieces snap off.
Old May 11, 2009 | 02:21 PM
blindS!de's Avatar
awesome thanks! i gotta do mine...
Old May 11, 2009 | 02:27 PM
Austin713's Avatar
anyone use the FRAM fresh breeze In cabin air filter? it is Carbon Activated and it apparently has Arm and hammer to trap moisture as well. its only like 13 bucks on amazon...
Old May 12, 2009 | 02:27 AM
tg1234's Avatar
Search on youtube and you can find a video how to. I believe. Also to my knowledge the fx and ex and G have the same size airfilter. But the FX has a little better filtering. You might want to look into change it out to that. Rick probably can tell us if it is true.
Old May 12, 2009 | 03:38 PM
dohturdima's Avatar
I just installed a MicronAir carbon filter in my G, the FRAM version is on order for dad's 07 Accord. Will have a look at it when it gets here, the Amazon reviews were decent.
Old May 12, 2009 | 05:25 PM
Austin713's Avatar
i ordered the fram because i figured.... might as well fram makes pretty decent stuff, i probably wont be able to tell the difference..... but i will let everyone know as well.
Old May 13, 2009 | 11:46 AM
jack090's Avatar
Wow I just changed my cabin filter and it was FILTHY (30k miles) There was like 2 small flys trapped in there to. I recommend definitiely changing it about 15k instead of the 30k like I did.
Old May 13, 2009 | 12:10 PM
Swivel's Avatar
Moderator
If anyone's interested, PM 'Christian', I think he has an activated charcoal one (the best kind) for sale.
Old May 13, 2009 | 02:20 PM
CalsonicVQ's Avatar
Yeah, it can get pretty gross. And your recommendation to change it every 15k miles?..That's actually the manufacturer's recommendation.
Old May 13, 2009 | 10:28 PM
greg_atlanta's Avatar
2008 G35 Journey Sedan no sunroof
Is the size the same for 03-06 & 07-08 models? Some brands say same size fit both, some don't.
http://www.infinitipartsusa.com only lists 03-06.
